rollbar pad, removal advice |
underdog |
Jul 10 2012, 07:39 AM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
Need advice on removing rollbar pad. I have removed the screws front and bottom but something seems to be holding it in place. Thanks.
ThePaintedMan |
Jul 10 2012, 08:06 AM
That should be it. Make sure you have all of them out. I had a couple that were stuck in the pad and couldn't be drawn all the way out. So I had to pull and unscrew them at the same time. Sometimes they just get stuck.
Bartlett 914 |
Jul 10 2012, 09:57 AM
Do you have the side bolsters out? I just installed one. I used a longer SS screw. It sure made it easier to put in.
Jeffs9146 |
Jul 10 2012, 10:20 AM
Did you forget the two screws inside the latch opening?
They are very hard to get to! |
ThePaintedMan |
Jul 10 2012, 10:25 AM
Type 47 |
Jul 10 2012, 09:13 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Be patient...I learned the hard way and now I can't find one to replace it.
The screws can be a long way into the padding and the heads can work their way crooked. If you don't have the screws all out they are probably still attached tp something. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:45 PM |
