underdog
Jul 10 2012, 07:39 AM
Need advice on removing rollbar pad. I have removed the screws front and bottom but something seems to be holding it in place. Thanks.
ThePaintedMan
Jul 10 2012, 08:06 AM
That should be it. Make sure you have all of them out. I had a couple that were stuck in the pad and couldn't be drawn all the way out. So I had to pull and unscrew them at the same time. Sometimes they just get stuck.
Bartlett 914
Jul 10 2012, 09:57 AM
Do you have the side bolsters out? I just installed one. I used a longer SS screw. It sure made it easier to put in.
Jeffs9146
Jul 10 2012, 10:20 AM
Did you forget the two screws inside the latch opening?
They are very hard to get to!
ThePaintedMan
Jul 10 2012, 10:25 AM
QUOTE(Jeffs9146 @ Jul 10 2012, 12:20 PM)
Good call. I just manipulated the lever and it made it easier.
Type 47
Jul 10 2012, 09:13 PM
Be patient...I learned the hard way and now I can't find one to replace it.
The screws can be a long way into the padding and the heads can work their way crooked. If you don't have the screws all out they are probably still attached tp something.
