Help my 914 cuts out, I am at a loss |
Dave Schiel |
Jul 12 2012, 10:33 AM
Newbie Group: Members Posts: 2 Joined: 12-July 12 From: Carlsbad CA Member No.: 14,662 Region Association: Southern California |
I have a 74 914 1.8 with Factory FI when I am driving the car will shut off for a second or 2, if I am driving it will kick back in, if I am sitting at a light sometimes it starts right up sometimes I have to crank it for upto 45 seconds (a long time when someone is honking) I have replaced the ignition switch ( the problem started prior to the replacement and continued after, bought a new switch from pelican parts). The fuel pump was replaced with a used one about a year ago with no problems and the vehicle has an aftermarket electronic Ignition. I have found no loose wires to date. Any help would be appreciated. Thanks in advance
benalishhero |
Jul 12 2012, 11:41 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Maybe look at the duel relay and connection (IMG:style_emoticons/default/confused24.gif)
Dave Schiel |
Jul 12 2012, 02:07 PM
I am not sure what that is |
Rand |
Jul 12 2012, 02:13 PM
It has to be spark or fuel... When dead and cranking, do you hear the fuel pump running?
Easy way to check spark is to pull a plug wire, stick a spare plug in it, and ground the threads to the case while cranking. You can see if it is sparking. Trouble is catching it right at that time of failure and having time to check before it fires again! How often does it do this? Good luck. |
benalishhero |
Jul 12 2012, 03:26 PM
I am not sure what that is The duel relay runs the FI and fuel pump. I've seen the female prongs in the connector back out resulting in a poor connection. |
Spoke |
Jul 12 2012, 04:57 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
When it dies while running, what does the tach do? Does it stay with the speed of the engine or drop to zero?
Sounds like an electrical problem somewhere. |
Jul 12 2012, 05:06 PM
The duel relay runs the FI and fuel pump. I've seen the female prongs in the connector back out resulting in a poor connection. (IMG:style_emoticons/default/agree.gif) If i'm not mistaken, it's next to the battery tray ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 03:06 AM |
