What size bolts/screws hold the back pad on? |
Matt Meyer |
Jul 14 2012, 10:47 AM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
I am putting the back pad on the 914 for the first time since I have owned the car. What size bolts or screws should attach the back pad.
The fine thread metric of the seat bolts and door panel handle bolts appear th be the correct diameter but wrong pitch. |
GeorgeRud |
Jul 14 2012, 10:59 AM
The top of the back pad is held in by brackets that are released by sliding the back pad vertically ( can't remember if it was up or down right now).
The bottom is held by some sheet metal screws if I remember correctly. They are probably number 10 or 12 size. Don't have my car here to check, but that should get you there. |
TheCabinetmaker |
Jul 14 2012, 11:37 AM
Oval head phillips sheet metal screw. Its a metric size but its not listed in the PET. A #8 or 10 should work. They used a trim washer too.
Ian Stott |
Jul 14 2012, 03:53 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I will be taking my back off once driving season is over, do you pull down or up after undoing the screws? Has anyone ever done the backpad in leather?
Ian Stott Moncton Canada |
TheCabinetmaker |
Jul 14 2012, 03:57 PM
After removing the screws at the bottom, pull the bottom out, and down.
Lo-Fi Version | Time is now: 20th May 2024 - 10:51 PM |
