Seat Belt Spring How to oil? |
kbrunk1 |
Jul 15 2012, 08:25 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Seat belts do not retract very good
Anyone know how to get to the area to oil them? Do you have to remove the stuff behind the seats? Thanks |
skaufmann |
Jul 16 2012, 09:58 PM
Blissfully Ignorant Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
If you haven't already, be certain the issue isn't with the seatbelt fabric stiff and dried up. So far all issues I've heard of (including me) are about the fabric not pliable so the spring loaded coil is no longer strong enough to retract. I've taken mine out (take seat backbad off) and lubricated with no help.
I've heard some people use 944 seat belts but there may be an issue with the receiver not fitting. I got what I was told were 944 seat belts at a 914 swap meet last year but they fit my existing receivers so I'm thinking they were 914s. |
davesprinkle |
Jul 16 2012, 11:18 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Adjust the wire loop so that the belt feeds straight into the spool without contacting the sides of the spool. You can do this by loosening the mounting bolt and readjusting. Easy.
PRS914-6 |
Jul 17 2012, 12:11 AM
DO NOT LUBE THEM!!! It is a magnet for dirt and the mechanism can fail when it's needed. They need to be clean and dry and lube doesn't help anyway because the springs are tired.
You can tighten the springs if your waist size is not too large and your webbing not too stiff. If you attempt tightening, understand the danger and wear safety gear as you can get severely hurt if the spring flies out. |
76-914 |
Jul 17 2012, 08:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Pull your seatbelt out all of the way to be sure it hasn't turned over on itself. This alone adds the equivalent of one extra wrap. Also polish the CP guide/strap that it goes thru. Los of drag here. Finally if it still is slow then you need to take it apart, clean and maybe add one or two revolutions of tightening to the spring. I'd do it for you but tooooooooooo much liability. Like trolling for lawyers. (IMG:style_emoticons/default/happy11.gif)
914Sixer |
Jul 17 2012, 07:24 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
This will sound silly but pull the belts all the way out to the end, use clothes pin or what ever to keep them from retracting and wash them. You will be amazed at the color of the water when you are done. This may take several attempts. Let them dry completely. The next day treat them with ScotchGard for fabrics. DO NOT ATTEMPT TO OPEN SEATBELT !!! The coil spring can hurt you when it explodes ! You might try a little silicon spray used sparingly around ratchet drive, it do not attract dirt readily.
Lo-Fi Version | Time is now: 21st May 2024 - 02:48 PM |
