How to Remove Electrical Connection on Master Cylinder |
kbrunk1 |
Jul 17 2012, 08:18 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Quick question but the Pelican Parts instructions just says to remove the electrical connection to the master cylinder.
Q) Does it just pull straight out? Q) Do you loosen the bolt just behind the electrical connection? How exactly do you remove it? My rubber boot is about to self destruct ..... Any help here? |
Black22 |
Jul 17 2012, 08:43 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Quick question but the Pelican Parts instructions just says to remove the electrical connection to the master cylinder. Q) Does it just pull straight out? Q) Do you loosen the bolt just behind the electrical connection? How exactly do you remove it? My rubber boot is about to self destruct ..... Any help here? IIRC its just a spade connector. The master cylinder side being the male end and the wire being the female connector. |
Krieger |
Jul 17 2012, 09:21 PM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
McMark |
Jul 17 2012, 10:34 PM
If you're removing the wires, they just pull off.
If you're removing the whole switch, it unscrews. Not really sure what project you're working on though... (IMG:style_emoticons/default/confused24.gif) |
broomhandle |
Jul 18 2012, 12:06 PM
Member Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
i just swithced from a 17 to a 19. the 17 has 2 conectors, the 19 has 1.
anybody know about this? |
Jul 18 2012, 12:14 PM
i just swithced from a 17 to a 19. the 17 has 2 conectors, the 19 has 1. anybody know about this? Yes. You simply tape up one connector and only use one. Works just fine ... (IMG:style_emoticons/default/popcorn[1].gif) |
broomhandle |
Jul 18 2012, 01:20 PM
i just swithced from a 17 to a 19. the 17 has 2 conectors, the 19 has 1. anybody know about this? Yes. You simply tape up one connector and only use one. Works just fine ... (IMG:style_emoticons/default/popcorn[1].gif) haha, thats what i did. it dose not matter which connector right? |
McMark |
Jul 18 2012, 02:02 PM
QUOTE it dose not matter which connector right? Yes. It does. Use the brown/white wire on the switch. Tape up the brown wire, as it's just a ground. |
broomhandle |
Jul 18 2012, 02:59 PM
cool... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 02:05 AM |
