MPS, I'm going to open one up- Test Results |
76-914 |
Jul 17 2012, 10:26 PM
Awhile back Lew Mengle gave me a beautiful looking MPS which he thought was rebuilt. I ohmed it out (I did this first in hopes that if it passed this test it would have a much better chance of passing the next test) and it tested OK. Next I checked to see if it would hold vacuum. Failed. Miserably at that. Couldn't get it to go beyond 5 no matter how fast I pumped that vacuum pump. So I tucked it away.
Last week I ordered 2 of the unobtanium diaphragms (that Chris @ Tangerine Racing is offering) so I thought I should get a head start on replacing one using my spare MPS. I don't mind telling you that I've always felt intimidated by these things so I'm looking forward to this about as much as fighting the school bully. My goal is to open this up without destroying it, clean it up and hopefully understand how to install the new diapragm and then return it to a setting that is very close to original. At that point I would hand it over to someone else to set to spec's with the proper equipment. I'm a little suspect of this particular unit as it appears someone's tinkered with the numbers. More to come in the following few days. |
SLITS |
Jul 18 2012, 07:09 AM
That unit has been "rebuilt" at least once in it's life as screws are not stock .. rivets are.
Getting the unit one to seal is the real problem when replacing the parts. I have torn apart about 5 of them attempting to replace the diaphragm. Then there is the seal around the electrical connector .... oh well. Some "rebuilders" will grind off the numbers, some don't. |
benalishhero |
Jul 18 2012, 09:17 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
76-914 |
Jul 18 2012, 07:51 PM
Again, I want to point out that any of this info is available at Brad Lander's site. I've read over his site, in it's entirety, several times yet I always find something new when I go back. Here is the unit with the epoxy removed as well as the stop screw. As I just mentioned, I want to return this to it's original state as close as I can, mechanically. So I marked the screw's slot position on the end w/ a Marks-a-lot. It was 9.75 turns or 9.75mm into the body, in that the thread pitch = 1.0. You gotta love that metric system, huh? I don't think I could figure that out in inch's. Inside is the set screw and nut where some of the adjustments are done. The other adjustment is that screw cap under the epoxy.
Next, in my case, is to remove the four screws holding the halves together. And behold, the Great and Powerful Oz. Shit, I'm a little disappointed. I was expecting some trumpets to go off, or something. I can now confirm what Ron just mentioned. I just hope he doesn't tell you the end. (IMG:style_emoticons/default/laugh.gif) I didn't know about the rivet/screw detail but I did read where Brad said repair shops often add an o-ring to supplement the existing NLA washer (we should tell Mikey914 about this). And this unit has both seals, so there you are. The o-ring is on the half to the left. This pic is the same shot except I have lifted and am holding the aneroid cell (is that right? I really don't know shit from apple butter about one of these things.) This is the mechanical device that reacts to vacuum changes, which in turn moves another device which converts it to an electrical signal and yadi, yadi, Go read about it at Brad's site; again damn it (IMG:style_emoticons/default/happy11.gif) . I've gotta say this cell looks to be in excellent shape but who knows? I'll need to pull a vacuum on it to see if it holds. The 3rd pic shows it has markings because I wasn't sure if there is an up/down when I disassembled it.. (IMG:style_emoticons/default/lol-2.gif) As far as I can tell, if this half were to leak it would have to be where this electrical plug penetrates the body; where the body has been compromised in some fashion i.e. cracked or split or uneven sealing surface; or where it mates to the other half. I'm trying to approach this from a common sense angle so I think I need to test case half's so I know which path to follow. I believe this half should be the easiest to test so I'll start here. After scurrying about I found this jar which mated the the OEM seal on the case half, perfectly. I pulled 15" vac and let it set for 15 min's. Whew, it passed and I'm glad because this side looks complicated. (IMG:style_emoticons/default/shades.gif) Next, I need to test the other half (the one with 3 openings on the end, hmmm) to determine if the diaphragm (that's the part Chris sells) is good/bad and whether the aneroid cell will hold, or not. More tomorrow. (IMG:style_emoticons/default/beerchug.gif) |
benalishhero |
Jul 18 2012, 08:22 PM
0396 |
Jul 18 2012, 08:27 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Sub...thanks!
914_teener |
Jul 18 2012, 09:59 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
You don't show the diaphragm? (IMG:style_emoticons/default/confused24.gif) It goes in front of the aneroid cell.
Bleyseng |
Jul 19 2012, 03:27 AM
where is the money shot? Open the cover!
(IMG:style_emoticons/default/popcorn[1].gif) |
EdwardBlume |
Jul 19 2012, 06:23 AM
SLITS |
Jul 19 2012, 09:51 AM
Bleyseng |
Jul 19 2012, 09:55 AM
note the double O rings to seal the cover to the body. I never do that as it seems to leak in time.
76-914 |
Jul 19 2012, 07:46 PM
OK, I'll cross my fingers and "hope" it is good. But let me draaaaaaaaaaaaaaaag this out a bit more. Before I jump to the "suspect" half I want to see if this cell will hold vacuum so I measured the cell first.
Then I sat it upon an upside down ceramic cup inside of a "Food Saver" vacuum canister (IMG:style_emoticons/default/biggrin.gif) . and pulled enough vacuum to make it expand maybe 1mm. Before: After: After it held for 15 min's I removed it and measured it to see if I had stretched it. Nope. Next, I began to fret about whether the cell would react to altitude changes properly and how do I check that. Would the upper limit be 12,000' ASL yadi, yadi....I then referred back to Brads site and there it was He had already done the homework and the numbers were there for 5"/10"/15"vac. This is turning out easier than I thought. (IMG:style_emoticons/default/w00t.gif) Armed with these numbers, my Food Saver Canister and my mighty vac I was able to nominally duplicate Brad's results as seen below. I'll take you for a tour thru my "Skunk Works" but you must never reveal any of my BS skills. This is a short piece of 2" PVC and centered quite nicely on the bottom is the cell. The dial indicator tip sits neatly atop the indented center of the aneroid cell. It was then just a matter of zeroing it out and drawing the vacuum. As you can see my overall movement was .080 or 2.032mm which is damn close to Brad's results so I'm good to go in this department. Now on to the other half. As you can see there is not much to it. Just 4 small screws or so I thought. That SoB was a trick. I didn't want to push it out with a dowel from the backside because I thought I might ruin something so I took an dental tool and snagged the edges of the screw holes and gently lifted as I cussed like a Drill Sgt. Eventually it lifted and revealed what Geoff so eloquently referred to as the Money shot. That is a gasket sitting in the housing. The silver plate that the 4 screws pass thru is under the diaphragm and isn't visible in this pic. Here is a better shot of the diaphragm. I can't find any tears or rips. I poured alcohol on it and it held. Plus, it's clean as a whistle except for moly grease it was set in w/ thegasket. (IMG:style_emoticons/default/beerchug.gif) I'm glad that I didn't abuse this when removing. (IMG:style_emoticons/default/biggrin.gif) Here are the misc pieces cleaned and dreased for the Family Photo: So it appears that the diaphragm is good yet there exists a leak on that side. You know what I think it is? This: The edge is wavered. I think the the gasket is hardened and the grease/gasket combo just wasn't enough. I think I'll 86 the gasket and go back w/ some gasket goo in hopes that it can fill those voids. If I remove this gasket I'd better get a measurement so I can compensate for it. And while that sets up I've found just the thing to test my new seal. More on this, later. Attached image(s) |
brant |
Jul 19 2012, 08:08 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
that diaphram looks to be stamped from brass...
all of the stock ones I've taken apart looked much more like copper so more confirmation that its been rebuilt and the aftermarket restamps are not supposed to flex the same as the original copper/berrilium, so this one may not have the same characteristics as a stock one when you get it back together.... I would throw a wide band on it if you can borrow one when your done. Its amazing how sensative the adjustment screws are. I am sure you will be able to get it back exactly as you found it... but less sure that the rebuilder got it exactly to the correct settings. brant |
ChrisFoley |
Jul 19 2012, 08:34 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Sometimes cracks are invisible until the edge is flexed enough to make the crack separate.
Most cracks propagate where the inner edge of the reinforcing ring and the housing on the other side contact the diaphragm, about 3/8" from the edge. That's where its under the most stress during operation. That looks like an oem diaphragm, but an older design, and I think I see a crack in the first closeup picture. Edit: However, it has different coloration, the ripples at the edge suggest less than perfect stamping, and it appears to have sealant around the hub. |
Bleyseng |
Jul 20 2012, 05:07 AM
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif)
That is not a OEM diaphragm or even a good rebuilt diaphragm. It looks to be soldered to the center piece so toss it in the "shitty parts bin" and wait for Chris's part. (IMG:style_emoticons/default/chair.gif) |
914_teener |
Jul 20 2012, 03:53 PM
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) That is not a OEM diaphragm or even a good rebuilt diaphragm. It looks to be soldered to the center piece so toss it in the "shitty parts bin" and wait for Chris's part. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/agree.gif) Yes that is definitely not copper beryllium diaphram and is a rebuilt unit plus.... Man...you are the man.....your wife lets you work on teener parts in the kitchen?... |
FourBlades |
Jul 20 2012, 04:29 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
This is an excellent thread, nice investigative work man! (IMG:style_emoticons/default/piratenanner.gif)
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif) John |
76-914 |
Jul 20 2012, 11:43 PM
Don't get caught up in the type of diaphragm. As I stated in the beginning, this is merely an exercise to prep me for the arrival of the parts I've ordered from Chris. I reuse that diaphragm as you will see in these pics because I'm chasing a leak and I want to see where they leak besides the obvious break or tear. BTW Geoff, that is solder and Chris, that isn't sealant but some grease that was used in conjunction with the gasket. Is that normal? Anyway, This is a look at what I used to make this tool. It's a 2" CI to PVC rubber coupling, an 1.5" PVC coupling, an 1.5" x 1/2" PVC bushing, 6" of 1/2" pipe and one 1/2" 90.
And when attached (I didn't glue anything so I could use it later he,he) you could see the conglomeration and the MPS body half in it. It was tight but it fit. The other end was large but tightened down nicely over the coupling. Do what you will here but I turned my compressor down to 1psi at the tip. Next I placed a 3/8" x 7/8" cone washer with a brass ring for reinforcement. The green stuff in the bottle is dish soap and filtered water. A small amount of this was poured around the edge of the flange and apply a small amount of air. The water cooler is just a 3rd hand, if you will. Well (IMG:style_emoticons/default/stromberg.gif) . Those bubbles don't look good so it's back to the drawing board. I think the "gasket maker" sealant was mis-used here. I should mention that I saved the NLA gasket and made one from the phone book cover. I installed it in the same order (MPS body, gasket, diaphragm then cover plate) but I believe that wavey assed diaphragm will need a gasket on both sides. And I'm going back with grease in hopes that the next gaskets will absorb it and swell a bit. Be back tomorrow. It's late. Attached image(s) |
ChrisFoley |
Jul 22 2012, 03:47 PM
... BTW Geoff, that is solder and Chris, that isn't sealant but some grease that was used in conjunction with the gasket. Is that normal? ... Factory assembled MPS diaphragms were installed dry, with just one paper gasket on the cover side, AFAIK. With that rippled edge on your diaphragm, I think RTV would have been better than grease. |
Bleyseng |
Jul 23 2012, 04:06 AM
I have seen 3-4 off those rebuilts with grease used as a sealant. WFT.
Lo-Fi Version | Time is now: 18th May 2024 - 08:05 PM |
