Again, I want to point out that any of this info is available at Brad Lander's site. I've read over his site, in it's entirety, several times yet I always find something new when I go back. Here is the unit with the epoxy removed as well as the stop screw. As I just mentioned, I want to return this to it's original state as close as I can, mechanically. So I marked the screw's slot position on the end w/ a Marks-a-lot. It was 9.75 turns or 9.75mm into the body, in that the thread pitch = 1.0. You gotta love that metric system, huh? I don't think I could figure that out in inch's. Inside is the set screw and nut where some of the adjustments are done. The other adjustment is that screw cap under the epoxy.
Click to view attachmentNext, in my case, is to remove the four screws holding the halves together. And behold, the Great and Powerful Oz. Shit, I'm a little disappointed. I was expecting some trumpets to go off, or something. I can now confirm what Ron just mentioned. I just hope he doesn't tell you the end.
I didn't know about the rivet/screw detail but I did read where Brad said repair shops often add an o-ring to supplement the existing NLA washer (we should tell Mikey914 about this). And this unit has both seals, so there you are. The o-ring is on the half to the left.
Click to view attachmentThis pic is the same shot except I have lifted and am holding the aneroid cell (is that right? I really don't know shit from apple butter about one of these things.) This is the mechanical device that reacts to vacuum changes, which in turn moves another device which converts it to an electrical signal and yadi, yadi, Go read about it at Brad's site; again damn it
Click to view attachmentI've gotta say this cell looks to be in excellent shape but who knows? I'll need to pull a vacuum on it to see if it holds. The 3rd pic shows it has markings because I wasn't sure if there is an up/down when I disassembled it..
Click to view attachment Click to view attachment Click to view attachmentAs far as I can tell, if this half were to leak it would have to be where this electrical plug penetrates the body; where the body has been compromised in some fashion i.e. cracked or split or uneven sealing surface; or where it mates to the other half.
Click to view attachmentI'm trying to approach this from a common sense angle so I think I need to test case half's so I know which path to follow. I believe this half should be the easiest to test so I'll start here. After scurrying about I found this jar which mated the the OEM seal on the case half, perfectly. I pulled 15" vac and let it set for 15 min's. Whew, it passed and I'm glad because this side looks complicated.
Click to view attachment Next, I need to test the other half (the one with 3 openings on the end, hmmm) to determine if the diaphragm (that's the part Chris sells) is good/bad and whether the aneroid cell will hold, or not. More tomorrow.
