Anyone know the torque spec on 2 liter connecting rods nuts, do we have a place this stuff is listed??? |
naro914 |
Jul 25 2012, 08:20 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
carr914 |
Jul 25 2012, 08:23 AM
Racer from Birth Group: Members Posts: 118,804 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I would ask on the Pelican Engine Builder Forum
Jul 25 2012, 08:36 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
2.o liter type 4 motor?
First page of the haynes manual, engine section. rich |
naro914 |
Jul 25 2012, 09:09 AM
2.o liter type 4 motor? Yes First page of the haynes manual, engine section. rich And if I had one handy, I wouldn't be asking... (IMG:style_emoticons/default/smile.gif) |
Jul 25 2012, 09:42 AM
Jul 25 2012, 09:43 AM
Always make sure that you inspect the threads for damage/stripping before using
Component ft-lb kg-m Size (dia x pitch) Connecting Rod Nut 24 3.3 M9 x 1 Crankcase Nut 14 2.0 M8 Crankcase Sealing Nut 25 3.5 M10 x 1.25 Cylinder-head nut (10mm stud) 23 3.2 M10 Rocker Shaft nut 10 1.4 M7 Heat exchanger / cyl. head 16 2.2 M8 Muffler / Heat Exchanger 14 2.0 M8 Oil drain plug 16 2.2 M12 x 1.5 Oil strainer nut 9 1.3 M8 Driveplate socket screw 65 9.0 M12 x 1.5 Hub to crankshaft bolt 23 3.2 M8 Fan to hub 14 2.0 M8 Pulley / Fan extension shaft 14 2.0 M8 Spark plug 22 3.0 M14 x 1.25 Engine to transaxle nut 22 3.0 M10 Cross member support to crankcase 22 3.0 M8 Rubberengine mount to cross member support or crankcase 14 2.0 M8 Cross member to chassis 14 2.0 M8 Vanagon rubber mounts to cross member 33 4.5 ? Oil pump to crankcase 14 2.0 M8 Oil cooler nut 5 0.7 M6 Flywheel bolt 80 11.0 M12 x 1.25 Clutch bolt 18 2.5 M8 x 20 Torque convertor to drvieplate 14 2.0 M8 |
Jul 25 2012, 09:44 AM
well, that did not work..
use the link |
naro914 |
Jul 25 2012, 11:39 AM
actually, that worked fine.
Thanks! |
TheCabinetmaker |
Jul 25 2012, 11:42 AM
Yep, it works Rich.
Valy |
Jul 25 2012, 11:13 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The table is missing one important fact: oiled threads. This is equivalent of about 30% more torque when dry.
Jul 26 2012, 11:03 AM
it was bothering me so I did a screen capture.
I fixed it. rich Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 05:15 AM |
