naro914
Jul 25 2012, 08:20 AM
carr914
Jul 25 2012, 08:23 AM
I would ask on the Pelican Engine Builder Forum
r_towle
Jul 25 2012, 08:36 AM
2.o liter type 4 motor?
First page of the haynes manual, engine section.
rich
naro914
Jul 25 2012, 09:09 AM
QUOTE(r_towle @ Jul 25 2012, 10:36 AM)
Yes
rich
And if I had one handy, I wouldn't be asking...
r_towle
Jul 25 2012, 09:42 AM
r_towle
Jul 25 2012, 09:43 AM
Always make sure that you inspect the threads for damage/stripping before using
Component
ft-lb
kg-m
Size (dia x pitch)
Connecting Rod Nut
24
3.3
M9 x 1
Crankcase Nut
14
2.0
M8
Crankcase Sealing Nut
25
3.5
M10 x 1.25
Cylinder-head nut (10mm stud)
23
3.2
M10
Rocker Shaft nut
10
1.4
M7
Heat exchanger / cyl. head
16
2.2
M8
Muffler / Heat Exchanger
14
2.0
M8
Oil drain plug
16
2.2
M12 x 1.5
Oil strainer nut
9
1.3
M8
Driveplate socket screw
65
9.0
M12 x 1.5
Hub to crankshaft bolt
23
3.2
M8
Fan to hub
14
2.0
M8
Pulley / Fan extension shaft
14
2.0
M8
Spark plug
22
3.0
M14 x 1.25
Engine to transaxle nut
22
3.0
M10
Cross member support to crankcase
22
3.0
M8
Rubberengine mount to cross member support or crankcase
14
2.0
M8
Cross member to chassis
14
2.0
M8
Vanagon rubber mounts to cross member
33
4.5
Oil pump to crankcase
14
2.0
M8
Oil cooler nut
5
0.7
M6
Flywheel bolt
80
11.0
M12 x 1.25
Clutch bolt
18
2.5
M8 x 20
Torque convertor to drvieplate
14
2.0
M8
r_towle
Jul 25 2012, 09:44 AM
well, that did not work..
use the link
naro914
Jul 25 2012, 11:39 AM
actually, that worked fine.
Thanks!
TheCabinetmaker
Jul 25 2012, 11:42 AM
Yep, it works Rich.
Valy
Jul 25 2012, 11:13 PM
The table is missing one important fact: oiled threads. This is equivalent of about 30% more torque when dry.
r_towle
Jul 26 2012, 11:03 AM
it was bothering me so I did a screen capture.
I fixed it.
rich
