Ethanol Rated Fuel Lines |
kbrunk1 |
Jul 31 2012, 07:26 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Was replacing all the fuel lines.
What brand or things do you look for to make sure it can handle ethanol. 2.0L FI 1973 moving to front and have 8mm stainless down the tunnel. Do the newer rubber lines have a stamped marking? |
TheCabinetmaker |
Jul 31 2012, 07:36 PM
We used to use Goodyear 30r, but there are several now that are high pressure, and compatible with all fuels. i use coline. Be sure to use the high pressure band clamps.some are marked. Yes.
Black22 |
Jul 31 2012, 07:38 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
JawjaPorsche |
Jul 31 2012, 07:40 PM
I got my hoses from NAPA plus fuel injector clamps. Ethanol will still eat up your hoses so check them regularly. If you can find a gas station that sells 100%, so much the better.
SLITS |
Jul 31 2012, 07:41 PM
Goodyear SAE 30R9 . Good luck finding it. I bought two 25' rolls (3/8" & 5/16") Cost was $250. It used to have a blue liner, but they had trouble with it rolling back when installed. It's now black. It's for our lovely ethanol based fuels.
Don't know if anyone else markets SAE 30R9. |
Mike Bellis |
Jul 31 2012, 07:42 PM
Anything that is CARB certified or legal for EFI in California will work.
SLITS |
Jul 31 2012, 07:44 PM
Anything that is CARB certified or legal for EFI in California will work. And you believe the gubermint pukes? (IMG:style_emoticons/default/biggrin.gif) |
JStroud |
Jul 31 2012, 08:03 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Goodyear SAE 30R9 . Good luck finding it. I bought two 25' rolls (3/8" & 5/16") Cost was $250. It used to have a blue liner, but they had trouble with it rolling back when installed. It's now black. It's for our lovely ethanol based fuels. Don't know if anyone else markets SAE 30R9. I just bought a 25' roll of 5/16" 30r9 from amazon 106.00 shipped. Jeff |
McMark |
Jul 31 2012, 08:36 PM
I just looked into all this and agree with above. But one thought that I had while doing research was that the "Not for fuel injection" hose has a working pressure of 50 psi and a burst pressure in the range of 100psi. I can understand why the manufacturer would print that on there (cover their asses), but since our system runs well below the working pressure of the carb line, why shouldn't we save money and use it?
Bartlett 914 |
Aug 1 2012, 05:09 AM
I recently found 30r9 at advance auto (a local flaps) very reasonable price. NAPA did not have it
ChrisFoley |
Aug 1 2012, 06:30 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I just looked into all this and agree with above. But one thought that I had while doing research was that the "Not for fuel injection" hose has a working pressure of 50 psi and a burst pressure in the range of 100psi. I can understand why the manufacturer would print that on there (cover their asses), but since our system runs well below the working pressure of the carb line, why shouldn't we save money and use it? In my experience, the pressurized fuel causes the hoses to soften and swell in only a few months time. After seeing that, I won't even use it for carbs. |
McMark |
Aug 1 2012, 10:05 AM
With Goodyear 30R9? They have a low pressure and a high pressure of the ethanol safe line.
nathansnathan |
Aug 1 2012, 11:01 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
30r9 is the SAE rating for the high pressure. 30r7 is the equivalent low pressure version. They have a flourolastemer (sp) (like silicone) lining. I bought some of the low pressure stuff in 3/8 for maybe $60 for 25'. It's too bad the EU doesn't have such crappy gas or we could get it in metric.
I wonder what they use in Brazil? ... nevermind (IMG:style_emoticons/default/beerchug.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-11782-1343840517.1.jpg) |
ChrisFoley |
Aug 1 2012, 11:13 AM
30R7 doesn't have the lining AFAIK.
nathansnathan |
Aug 1 2012, 11:55 AM
McMark |
Aug 1 2012, 12:18 PM
Ahhhh, apparently I misunderstood the specs, or they're different for the Gates Barricade hose. I probably will never use the low-pressure line, but I will always wonder since the Gates Barricade line indicates it's the same construction quality (NOT 30R7) which implies the fuel injection line is simply better rated for pressure. Oh well. It's not like we're even talking about a worthwhile cost savings.
https://www.youtube.com/watch?v=0GZxw7hwR6k |
ape914 |
Aug 1 2012, 12:48 PM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
30r9 is the SAE rating for the high pressure. 30r7 is the equivalent low pressure version. They have a flourolastemer (sp) (like silicone) lining. I bought some of the low pressure stuff in 3/8 for maybe $60 for 25'. It's too bad the EU doesn't have such crappy gas or we could get it in metric. I wonder what they use in Brazil? ... nevermind (IMG:style_emoticons/default/beerchug.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-11782-1343840517.1.jpg) Actually 30R7 and 30R9 are different mainly in that 30R9 is lined to resist the oxygenated fuels, 30R7 is not. these ratings are by the SAE (Society of Automotive Engineers) 30R9 also has a considerably lower permiability to gasoline than 30R7 i think it was something like over thirty times less permiable to gasoline vapours. Hence 30R7 is not allowed to be used as a replacement on newer smog controlled cars. use of 30r9 reduces the hydrocarbon smog problem. even when a car is just sitting, it is polluting by outgassing of the fuel. 30r9 reduces the hoses role as a source for this pollution. 30R7 will degrade in high oxygenated gasoline. 30R7 used to be specified for FI pressures. now we are starting to see 30R7 marked as unsafe for FI pressures. that is because the new fuels will weaken 30R7 over long exposures and can cause it to fail at high pressure. |
patssle |
Aug 2 2012, 03:14 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I've had this same problem, but for my jet skis. Rebuilding the carbs on my 1995 Seadoo and been trying to find affordable fuel hose. Ugh!
I have found this and Gates is a big manufacturer: http://images.oreillyauto.com/parts/img/do...ricade4page.pdf Haven't bought it, but found it cheap on Amazon - reseller has good reviews. (for carbs - this size is 1/4") http://www.amazon.com/Gates-Rubber-Company...e/dp/B00498CX2M |
damesandhotrods |
Aug 2 2012, 05:35 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
benalishhero |
Aug 2 2012, 05:43 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
FWIW, I have been using Gates hose rated for EFI in E10 land for a number of years no problem....
Lo-Fi Version | Time is now: 17th May 2024 - 02:14 PM |
