New Gauges |
New Gauges |
ww914 |
Aug 1 2012, 08:23 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Awhile back some of us group bought CHT gauges and wideband air/fuel mixture gauges. Any reports on how they are working out for you?
It may be overkill, but I love my CHT display. It may be more info than I need, but it's nice to see what is going on. As far as the air/fuel gauge goes, I absolutely think that this is the only way to go to tune your carbs to perfection. I am sure this has been said before, but now I am a true believer. I can't keep my eye off the dam thing. Not sure if that is a good thing or not, but I sure know if I am running lean or rich at every throttle position. I suppose when I get it tuned they way I want, I won't stare at it as much. Here are the three new gauges I have installed: The top one is the MGL Avionics TC-2 4 channel CHT gauge. The middle one is the AEM Wideband Air/Fuel Ratio gauge. The bottom one is an oil pressure gauge. I built this new insert and saved the original setup. This is how I installed the probes. I didn't use existing spark plugs holes, but cut new holes and inserted grommets. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:12 PM |
