Valve Train mods, While I am in there...... |
jeffdon |
Aug 1 2012, 01:45 PM
Getting set to drop the engine so I can have a sparkplug hole repaired.
While out, I am considering finally going through my valve train geometry, cutting custom pushrods, and going to swivel feet adjusters. Does anyone have experience with the 9mm Rhino feet from CB performance? They are WAY less expensive than Porsche units, and would negate having to switch to 1.7 rockers. Are they good, or just Chinese junk? |
TheCabinetmaker |
Aug 1 2012, 01:52 PM
I have not used the chinese stuff, but the 911 adjusters must use the 1.7 rockers. The 2.0L rockers have a bigger adjuster thread.
I really don't see you have anything to gain with a stock engine. |
jeffdon |
Aug 1 2012, 02:00 PM
TheCabinetmaker |
Aug 1 2012, 02:07 PM
Well nevermind then! My 2056 has all the valve train upgrades but the heavey duty springs. Even with stock springs the rev in the upper limits is smoother. I like adjusting the valves at zero lash with the chromemoly pusrods.
jeffdon |
Aug 1 2012, 02:10 PM
Well nevermind then! My 2056 has all the valve train upgrades but the heavey duty springs. Even with stock springs the rev in the upper limits is smoother. I like adjusting the valves at zero lash with the chromemoly pusrods. Good to know. What procedure are you using to measure zero lash? |
McMark |
Aug 1 2012, 02:43 PM
They way I think of it:
Porsche builds components that live up the their long reputation of quality. CBPerformance builds (rather RESELLS) components that meet a price point. Quality isn't the first priority. So if your first priority is cost, buy the CBPerformance pieces. If your first priority is quality and long life, shell out for the Porsche components. |
jeffdon |
Aug 1 2012, 02:47 PM
They way I think of it: Porsche builds components that live up the their long reputation of quality. CBPerformance builds (rather RESELLS) components that meet a price point. Quality isn't the first priority. So if your first priority is cost, buy the CBPerformance pieces. If your first priority is quality and long life, shell out for the Porsche components. Good point, Mark. What would your take be on used 911 adjusters if I can find them? |
Katmanken |
Aug 1 2012, 02:50 PM
McMark |
Aug 1 2012, 03:33 PM
I don't think I've heard of OE swivels going bad. New would make me feel better. But used OE would be a good second place unless someone else chimes in with stories of swivel failure.
Valy |
Aug 1 2012, 03:44 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I would evaluate the state of the cam before doing any changes. The 911 adjusters only at high lift. If your cam is worn out than you better not add heavier lifters. Also old valve springs won't like the heavier lifters as well.
jeffdon |
Aug 1 2012, 08:26 PM
I would evaluate the state of the cam before doing any changes. The 911 adjusters only at high lift. If your cam is worn out than you better not add heavier lifters. Also old valve springs won't like the heavier lifters as well. The cam is higher lift than stock....springs are stock....really confused now. |
McMark |
Aug 1 2012, 11:47 PM
The swivel foot adjusters are hardly heavier than stock. And if you were to cut off the excess thread they would probably be lighter. Not that I'd promote that.
euro911 |
Aug 2 2012, 12:47 AM
We're also running a 2056, Mahle jugs, Keith Black pistons, Raby spec'd heads with 44/38mm S/S valves, 9.0:1 C/R, 9580 cam, chromemoly push rods, 911 swivels and clearanced 1.7L rocker arms.
Just a suggestion, but if you're having one spark plug hole repaired, it's a good idea to have steel inserts installed in all four holes ... no more stripped or cross-thread issues (IMG:style_emoticons/default/idea.gif) |
jeffdon |
Aug 2 2012, 07:34 AM
We're also running a 2056, Mahle jugs, Keith Black pistons, Raby spec'd heads with 44/38mm S/S valves, 9.0:1 C/R, 9580 cam, chromemoly push rods, 911 swivels and clearanced 1.7L rocker arms. Just a suggestion, but if you're having one spark plug hole repaired, it's a good idea to have steel inserts installed in all four holes ... no more stripped or cross-thread issues (IMG:style_emoticons/default/idea.gif) Considering this, but have heard somewhere that the 2.0 heads have less heat dissipating ability around the plugs, which is further diminished with the inserts. But I am thinking, really, how much material could you loose? |
Valy |
Aug 2 2012, 08:48 AM
I would evaluate the state of the cam before doing any changes. The 911 adjusters only at high lift. If your cam is worn out than you better not add heavier lifters. Also old valve springs won't like the heavier lifters as well. The cam is higher lift than stock....springs are stock....really confused now. The cam HAD higher lift that stock when new. You should check how much is left of that lift. Not implying that your cam is gone but I've seen flat cams on low mileage engines. |
jeffdon |
Aug 2 2012, 09:00 AM
I would evaluate the state of the cam before doing any changes. The 911 adjusters only at high lift. If your cam is worn out than you better not add heavier lifters. Also old valve springs won't like the heavier lifters as well. The cam is higher lift than stock....springs are stock....really confused now. The cam HAD higher lift that stock when new. You should check how much is left of that lift. Not implying that your cam is gone but I've seen flat cams on low mileage engines. After only 8k miles? It would be scary to see a significant reduction in lift after only 8k. |
ChrisFoley |
Aug 2 2012, 11:02 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Its even worse when the cam goes flat in less than 80 miles. (IMG:style_emoticons/default/unsure.gif)
It happens. |
jeffdon |
Aug 2 2012, 12:10 PM
Its even worse when the cam goes flat in less than 80 miles. (IMG:style_emoticons/default/unsure.gif) It happens. The cam and lifters are new, the springs are standard, running brad penn oil, so unless I got a flawed cam, what would cause such rapid wear? |
euro911 |
Aug 2 2012, 12:16 PM
... Just a suggestion, but if you're having one spark plug hole repaired, it's a good idea to have steel inserts installed in all four holes ... no more stripped or cross-thread issues (IMG:style_emoticons/default/idea.gif) Considering this, but have heard somewhere that the 2.0 heads have less heat dissipating ability around the plugs, which is further diminished with the inserts. But I am thinking, really, how much material could you loose?...The cam and lifters are new, the springs are standard, running brad penn oil, so unless I got a flawed cam, what would cause such rapid wear? How did you originally break-in the engine? (2,500RPM for 20 minutes?) |
ChrisFoley |
Aug 2 2012, 12:27 PM
Its even worse when the cam goes flat in less than 80 miles. (IMG:style_emoticons/default/unsure.gif) It happens. The cam and lifters are new, the springs are standard, running brad penn oil, so unless I got a flawed cam, what would cause such rapid wear? In the case I mentioned, it was a combination of high spring pressures and improperly hardened lifters against a fairly high lift cam. If you got 8K miles already and you're using Brad Penn, I doubt you have a flat cam. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:20 PM |
