jeffdon
Aug 1 2012, 01:45 PM
Getting set to drop the engine so I can have a sparkplug hole repaired.
While out, I am considering finally going through my valve train geometry, cutting custom pushrods, and going to swivel feet adjusters.
Does anyone have experience with the 9mm Rhino feet from CB performance? They are WAY less expensive than Porsche units, and would negate having to switch to 1.7 rockers.
Are they good, or just Chinese junk?
TheCabinetmaker
Aug 1 2012, 01:52 PM
I have not used the chinese stuff, but the 911 adjusters must use the 1.7 rockers. The 2.0L rockers have a bigger adjuster thread.
I really don't see you have anything to gain with a stock engine.
jeffdon
Aug 1 2012, 02:00 PM
QUOTE(The Cabinetmaker @ Aug 1 2012, 12:52 PM)
Its not stock. 2056 with webers and a webcam #494.
TheCabinetmaker
Aug 1 2012, 02:07 PM
Well nevermind then! My 2056 has all the valve train upgrades but the heavey duty springs. Even with stock springs the rev in the upper limits is smoother. I like adjusting the valves at zero lash with the chromemoly pusrods.
jeffdon
Aug 1 2012, 02:10 PM
QUOTE(The Cabinetmaker @ Aug 1 2012, 01:07 PM)
Good to know. What procedure are you using to measure zero lash?
McMark
Aug 1 2012, 02:43 PM
They way I think of it:
Porsche builds components that live up the their long reputation of quality.
CBPerformance builds (rather RESELLS) components that meet a price point. Quality isn't the first priority.
So if your first priority is cost, buy the CBPerformance pieces. If your first priority is quality and long life, shell out for the Porsche components.
jeffdon
Aug 1 2012, 02:47 PM
QUOTE(McMark @ Aug 1 2012, 01:43 PM)
Good point, Mark. What would your take be on used 911 adjusters if I can find them?
Katmanken
Aug 1 2012, 02:50 PM
McMark
Aug 1 2012, 03:33 PM
I don't think I've heard of OE swivels going bad. New would make me feel better. But used OE would be a good second place unless someone else chimes in with stories of swivel failure.
Valy
Aug 1 2012, 03:44 PM
I would evaluate the state of the cam before doing any changes. The 911 adjusters only at high lift. If your cam is worn out than you better not add heavier lifters. Also old valve springs won't like the heavier lifters as well.
jeffdon
Aug 1 2012, 08:26 PM
QUOTE(Valy @ Aug 1 2012, 02:44 PM)
The cam is higher lift than stock....springs are stock....really confused now.
McMark
Aug 1 2012, 11:47 PM
The swivel foot adjusters are hardly heavier than stock. And if you were to cut off the excess thread they would probably be lighter. Not that I'd promote that.
euro911
Aug 2 2012, 12:47 AM
We're also running a 2056, Mahle jugs, Keith Black pistons, Raby spec'd heads with 44/38mm S/S valves, 9.0:1 C/R, 9580 cam, chromemoly push rods, 911 swivels and clearanced 1.7L rocker arms.
Just a suggestion, but if you're having
one spark plug hole repaired, it's a good idea to have steel inserts installed in
all four holes ... no more stripped or cross-thread issues
jeffdon
Aug 2 2012, 07:34 AM
QUOTE(euro911 @ Aug 1 2012, 11:47 PM)
Considering this, but have heard somewhere that the 2.0 heads have less heat dissipating ability around the plugs, which is further diminished with the inserts. But I am thinking, really, how much material could you loose?
Valy
Aug 2 2012, 08:48 AM
QUOTE(jeffdon @ Aug 1 2012, 07:26 PM)
The cam HAD higher lift that stock when new. You should check how much is left of that lift.
Not implying that your cam is gone but I've seen flat cams on low mileage engines.
jeffdon
Aug 2 2012, 09:00 AM
QUOTE(Valy @ Aug 2 2012, 07:48 AM)
After only 8k miles? It would be scary to see a significant reduction in lift after only 8k.
ChrisFoley
Aug 2 2012, 11:02 AM
Its even worse when the cam goes flat in less than 80 miles.
It happens.
jeffdon
Aug 2 2012, 12:10 PM
QUOTE(Racer Chris @ Aug 2 2012, 10:02 AM)
It happens.
The cam and lifters are new, the springs are standard, running brad penn oil, so unless I got a flawed cam, what would cause such rapid wear?
euro911
Aug 2 2012, 12:16 PM
QUOTE(jeffdon @ Aug 2 2012, 06:34 AM)
... Just a suggestion, but if you're having
If that's a concern, Time-Sert sells copper inserts that transfer heat better.
QUOTE(jeffdon @ Aug 2 2012, 11:10 AM)
...The cam and lifters are new, the springs are standard, running brad penn oil, so unless I got a flawed cam, what would cause such rapid wear?
How did you originally break-in the engine? (2,500RPM for 20 minutes?)
ChrisFoley
Aug 2 2012, 12:27 PM
QUOTE(jeffdon @ Aug 2 2012, 01:10 PM)
It happens.
In the case I mentioned, it was a combination of high spring pressures and improperly hardened lifters against a fairly high lift cam.
If you got 8K miles already and you're using Brad Penn, I doubt you have a flat cam.
Valy
Aug 2 2012, 01:14 PM
It happens.
It doesn't have to be flat. I'm not trying to scare you
Just check the lift with a dialmeter on the rockers. It's very simple.
The point is that it's easier to check before you get into all the trouble of replacing the valve train. And since the push-rods are custom-cut for your engine, it will be a waste of money to cut them for a worn-out cam.
A lot of the cam wear happens in the initial brake-in period but there is permanent wear all the time. I've seen a webcam out of a ~10K engine that had 2mm shaved off the lobes without any apparent abuse to the engine.
jeffdon
Aug 2 2012, 01:38 PM
QUOTE(Valy @ Aug 2 2012, 12:14 PM)
It happens.
Webcam making inferior cams?
jeffdon
Aug 2 2012, 01:39 PM
QUOTE(euro911 @ Aug 2 2012, 11:16 AM)
THANKS!
Yep, thats what I did.
Valy
Aug 2 2012, 02:24 PM
QUOTE(jeffdon @ Aug 2 2012, 12:38 PM)
It happens.
No, that's not the point. It can happen to any cam but it so happened that the one I've witnessed was a webcam. I still have it if you want to see it.
My new cam is a webcam as well so it's not that I'm saying that webcams are bad.
The engine was still running strong with that cam so you never know until you check.
McMark
Aug 2 2012, 02:34 PM
Jeffdon, if your cam was losing lift, you'd notice that you had to adjust the valves every time to checked them. Had any adjusters that were seriously loose?
jeffdon
Aug 2 2012, 02:35 PM
QUOTE(McMark @ Aug 2 2012, 01:34 PM)
No. Matter of fact, only about half needed any adjust at all last time. Minor at that.
Valy
Aug 2 2012, 02:36 PM
Sorry Mark, you are wrong this time.
The cam has almost no wear at the low point, where the valve adjustment is done. All the wear is on the lobe and there is no way to see that just from valve adjustment. You have to measure it.
McMark
Aug 2 2012, 02:46 PM
My point is that you don't lose 2mm off your cam lobe and not notice something's wrong.
HAM Inc
Aug 2 2012, 06:24 PM
Mark's right. When the cam wears so does the lifter, usually (but not always) even more than the cam.
The swivel screws are a great upgrade even for stock cams. The reduction in side loading of the valve combined with the reduced friction at the stem/adjuster interface is very beneficial. Valve guides last longer and so do the valves.
Use genuine Porsche adjusters if you plan to keep the car and only want to do it once.
The swivel screws do weigh a bit more than the stock adjusters, but the material you remove when the rockers are clearanced for the screws makes up for it.
