205 50 15 tire size |
Bertus |
Aug 5 2012, 09:45 PM
Member Group: Members Posts: 222 Joined: 2-May 05 From: Lexington, KY Member No.: 4,021 Region Association: South East States |
I am currently running 205 65 15s street tires on my fuchs. Looking to upgrade to a extreme performance summer tire 205 50 15s. Could there be a clearance issue with going to the 205 50 15s? Have about 5 inches of clearance in the front. Didn't appear to be any extreme performance tires in 55 or 60.
Thanks for any input! |
Randal |
Aug 5 2012, 10:12 PM
I am currently running 205 65 15s street tires on my fuchs. Looking to upgrade to a extreme performance summer tire 205 50 15s. Could there be a clearance issue with going to the 205 50 15s? Have about 5 inches of clearance in the front. Didn't appear to be any extreme performance tires in 55 or 60. Thanks for any input! Are you looking for a street tire or a racing tire and if a racing tire which venues? |
wndsrfr |
Aug 6 2012, 06:14 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I am currently running 205 65 15s street tires on my fuchs. Looking to upgrade to a extreme performance summer tire 205 50 15s. Could there be a clearance issue with going to the 205 50 15s? Have about 5 inches of clearance in the front. Didn't appear to be any extreme performance tires in 55 or 60. Thanks for any input! DML Tire calculator gives you all the info you want......... |
Bertus |
Aug 6 2012, 06:24 AM
Tires would be for autocross. Originally I was going to get another set of rims and get a more aggressive race tire, but due to financial constraints I was thinking of getting something I could drive to the track. Been looking at Kumho Ecsta XS and Yokohama Advan Neova AD08. Since the car sits so low already (PO may have lowered the front) I am a little concerned that going to the 50 that I will be too low to the ground.
Randal |
Aug 6 2012, 09:12 AM
Tires would be for autocross. Originally I was going to get another set of rims and get a more aggressive race tire, but due to financial constraints I was thinking of getting something I could drive to the track. Been looking at Kumho Ecsta XS and Yokohama Advan Neova AD08. Since the car sits so low already (PO may have lowered the front) I am a little concerned that going to the 50 that I will be too low to the ground. Your idea is a good one. Just save your money and get a set of Hoosiers and put them on different rims. Like cookie cutters that I just sold for $50.00 each. Get the Hoosiers hot and they stick like nothing else. Here is a picture of my car with 205's on it before the car was flared. You will love them, seriously. (IMG:style_emoticons/default/smilie_pokal.gif) And don't forget to dial in some camber when you run Hoosiers. Also if your going to spend money on good tires, like the Hoosiers, make sure your car is corner balanced. CBing is maybe one of the most important things you can do. |
Bertus |
Aug 6 2012, 09:47 AM
Thanks Randal. Appreciate the advice.
steuspeed |
Aug 6 2012, 01:06 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I just got a set of these Dunlop Direzza Z1 Star Spec tires in a 195/55/15. My second set of Fuch wheels should be delivered today. I think its going to be a nice combo of light weight tire plus stickiness. Shorter than stock, but taller than a 205/50/15.
http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes |
Bertus |
Aug 6 2012, 02:40 PM
I just got a set of these Dunlop Direzza Z1 Star Spec tires in a 195/55/15. My second set of Fuch wheels should be delivered today. I think its going to be a nice combo of light weight tire plus stickiness. Shorter than stock, but taller than a 205/50/15. http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes Something to think about. Thanks. |
Woody |
Aug 6 2012, 06:22 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
You didn't mention if you were looking for a DOT competition tire. Last year I was using Toyo RA1s in 205/50/15 as a compromise between street and AX before I went 5 lug and flared. I think it was a good tire for where I was at the time. Now I run hankook AX tires on a separate set of rims and use what's left of the toyos on the street.
Bertus |
Aug 6 2012, 08:29 PM
You didn't mention if you were looking for a DOT competition tire. Last year I was using Toyo RA1s in 205/50/15 as a compromise between street and AX before I went 5 lug and flared. I think it was a good tire for where I was at the time. Now I run hankook AX tires on a separate set of rims and use what's left of the toyos on the street. I ended up ordering a set of Kumho ECSTA XS today, which seem to be a decent in between tire. Eventually I want to get another set of rims with track tires on them. I have a lot of AX driving/learing to do before I jump into that though. |
Woody |
Aug 7 2012, 12:31 PM
You didn't mention if you were looking for a DOT competition tire. Last year I was using Toyo RA1s in 205/50/15 as a compromise between street and AX before I went 5 lug and flared. I think it was a good tire for where I was at the time. Now I run hankook AX tires on a separate set of rims and use what's left of the toyos on the street. I have a lot of AX driving/learing to do before I jump into that though. Well said. My car is well set up, not exactly where I want it but getting close. I think though before I go spending more money I could shave serious time by being smoother and putting forth an effort to improve my driving. |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:42 PM |
