First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
Eric_Shea |
Aug 14 2012, 08:16 AM
The time has come. We are beginning to take pre-orders on the 914-6 rear calipers.
As you know, us 914 owners have long been looking for a solution to a properly biased brake system. The fronts have been the easy part, bolt on a pair of Brembo's ...or a 3.5" 911 front suspension and you would have your choice of larger calipers with 48mm pistons up front. But, what about the rears? You need a 38mm piston to give you the correct bias. For 914 owners that meant a long and winding road of searching for the proper solution which usually boiled down to two things; uber-rare (and uber-expensive) original 914-6 calipers or 911 rear calipers and a confusing handbrake assembly or, worse yet, 911 rear calipers and no handbrake solution. Well, you're looking at the true bolt on solution. Aluminum castings of the famous 914-6 rear calipers. Final weigh-in has yet to be established but, we think we'll be under 3lbs each with the aluminum pistons. These simply bolt on and use stock handbrake cables and parts. Larger pistons and larger pads make this the prefect rear caliper solution for Brembo bolt-ons and S-Caliper or A-Caliper upgrades. What you are looking at is a raw alloy assembled prototype prior to anodizing. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953789.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953790.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1344953790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953791.4.jpg) |
IronHillRestorations |
Aug 16 2012, 04:42 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Porsche has put aluminum calipers on their top of the line cars for years. Remember when the S alloy calipers were the top shelf?
One guy writes about "flex" and causes speculation. 99% of the guys in the 914 world are stoked! Awesome stuff Sir Eric of Stoppage! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
Matt Romanowski |
Aug 16 2012, 07:25 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Porsche has put aluminum calipers on their top of the line cars for years. Remember when the S alloy calipers were the top shelf? One guy writes about "flex" and causes speculation. 99% of the guys in the 914 world are stoked! Awesome stuff Sir Eric of Stoppage! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) I'm not saying it's not really cool that he's doing this, but I'm asking about the material. Go look at other aluminum calipers and you'll notice something really different - they are forged. As you know, the forging adds a lot of strength. Now, I'm not saying that you these won't be good calipers, I'm asking if they have been tested and work. Taking a design that was engineered for steel and making them out of aluminum isn't guarenteed to work the same. |
mepstein |
Aug 16 2012, 09:00 PM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Porsche has put aluminum calipers on their top of the line cars for years. Remember when the S alloy calipers were the top shelf? One guy writes about "flex" and causes speculation. 99% of the guys in the 914 world are stoked! Awesome stuff Sir Eric of Stoppage! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) I'm not saying it's not really cool that he's doing this, but I'm asking about the material. Go look at other aluminum calipers and you'll notice something really different - they are forged. As you know, the forging adds a lot of strength. Now, I'm not saying that you these won't be good calipers, I'm asking if they have been tested and work. Taking a design that was engineered for steel and making them out of aluminum isn't guarenteed to work the same. If you want tried and tru steel, I have a new set of perfect PMB 914-6 GT calipers I can sell you. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:18 AM |
