First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
Eric_Shea |
Aug 14 2012, 08:16 AM
The time has come. We are beginning to take pre-orders on the 914-6 rear calipers.
As you know, us 914 owners have long been looking for a solution to a properly biased brake system. The fronts have been the easy part, bolt on a pair of Brembo's ...or a 3.5" 911 front suspension and you would have your choice of larger calipers with 48mm pistons up front. But, what about the rears? You need a 38mm piston to give you the correct bias. For 914 owners that meant a long and winding road of searching for the proper solution which usually boiled down to two things; uber-rare (and uber-expensive) original 914-6 calipers or 911 rear calipers and a confusing handbrake assembly or, worse yet, 911 rear calipers and no handbrake solution. Well, you're looking at the true bolt on solution. Aluminum castings of the famous 914-6 rear calipers. Final weigh-in has yet to be established but, we think we'll be under 3lbs each with the aluminum pistons. These simply bolt on and use stock handbrake cables and parts. Larger pistons and larger pads make this the prefect rear caliper solution for Brembo bolt-ons and S-Caliper or A-Caliper upgrades. What you are looking at is a raw alloy assembled prototype prior to anodizing. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953789.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953790.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1344953790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953791.4.jpg) |
Eric_Shea |
Aug 16 2012, 11:52 PM
The Brembos we sell are cast. Same process. No flex. Much larger 48mm pistons as well. Everyone we've sold them to absolutely loves them.
Not sure about all the flex talk in calipers. Vic Elford can win Monte Carlo and race at Le Mans on aluminum calipers for 24 hours yet I hear from a lot of Internet racers that can't make it a lap around Riverside without complaining about "flex". I have aluminum calipers on all my cars. I love them and highly recommend them. |
Matt Romanowski |
Aug 17 2012, 06:45 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The Brembos we sell are cast. Same process. No flex. Much larger 48mm pistons as well. Everyone we've sold them to absolutely loves them. Not sure about all the flex talk in calipers. Vic Elford can win Monte Carlo and race at Le Mans on aluminum calipers for 24 hours yet I hear from a lot of Internet racers that can't make it a lap around Riverside without complaining about "flex". I have aluminum calipers on all my cars. I love them and highly recommend them. I have aluminum calipers on both of my cars. They were all designed from the beginning to be made out of aluminum. Brembo, Alcon, PFC, Wilwood, etc all spend huge amounts of resources on trying to make their calipers stiffer. Will there be unintended consequences of changing the same design from steel to aluminum? No doubt. Are they big enough to be a problem? Don't know - that's why I asked if you had used these calipers yet. Just becuase they were good 44 years ago doesn't mean they are good today. Wanna argue that Goodyear Blue Streaks are as good as Hoosiers? Maybe we should all use slide rules instead of computers becuase that is what they used when they engineered stuff for Vic's car? I hope these are great calipers and work well. I think it's awesome that you are developing parts for 914s (and Porsches in general). I'm not trying to be a jerk, but changing the material a brake caliper is made out of is a major change. I think it's appropriate to ask if this was an engineered, analyzed change or just one of ease of manufacture or becuase it is lighter. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:37 AM |
