First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
Eric_Shea |
Aug 14 2012, 08:16 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The time has come. We are beginning to take pre-orders on the 914-6 rear calipers.
As you know, us 914 owners have long been looking for a solution to a properly biased brake system. The fronts have been the easy part, bolt on a pair of Brembo's ...or a 3.5" 911 front suspension and you would have your choice of larger calipers with 48mm pistons up front. But, what about the rears? You need a 38mm piston to give you the correct bias. For 914 owners that meant a long and winding road of searching for the proper solution which usually boiled down to two things; uber-rare (and uber-expensive) original 914-6 calipers or 911 rear calipers and a confusing handbrake assembly or, worse yet, 911 rear calipers and no handbrake solution. Well, you're looking at the true bolt on solution. Aluminum castings of the famous 914-6 rear calipers. Final weigh-in has yet to be established but, we think we'll be under 3lbs each with the aluminum pistons. These simply bolt on and use stock handbrake cables and parts. Larger pistons and larger pads make this the prefect rear caliper solution for Brembo bolt-ons and S-Caliper or A-Caliper upgrades. What you are looking at is a raw alloy assembled prototype prior to anodizing. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953789.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953790.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1344953790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953791.4.jpg) |
Eric_Shea |
Aug 17 2012, 08:41 AM
Sorry Rob. These will flex way too much for you. (IMG:style_emoticons/default/biggrin.gif)
The Brembos were cast copies of ATE steel A-Calipers. Hey Rob, how are your Brembos working out? Tensile Strengths Steel and Aluminum Structural steel ASTM A36 Steel Yield strength (MPa) = 250 Carbon steel 1090 Yield strength (MPa) = 250 Aluminium Yield strength (MPa) = 414 Human skin (mine is getting thicker with all this Internet philosophic discussion) (IMG:style_emoticons/default/biggrin.gif) Yield strength (MPa) = 15 Aluminum (IMG:http://www.914world.com/bbs2/uploads_offsite/upload.wikimedia.org-1110-1345214481.1.png) 1. Ultimate strength 2. Yield strength 3. Proportional limit stress 4. Fracture 5. Offset strain (typically 0.2%) Steel (IMG:http://www.914world.com/bbs2/uploads_offsite/upload.wikimedia.org-1110-1345214481.2.png) 1. Ultimate strength 2. Yield strength 3. Fracture 4. Strain hardening region 5. Necking region A: Engineering stress B: True stress The Yield Strength of aluminum will always be the same regardless of the "caliper design". Now, let's get into real world observations: I've "NEVER" seen a broken aluminum caliper but I've seen "innumerable" steel calipers with mounting ears fractured off and sealing flanges fractured. Steel is much more brittle than aluminum. The aforementioned Brembos have been in use since the mid-70's and again, I've "never" seen one broken or fractured. Same material depth on the mounting ears and around the piston flanges. Again, an aluminum copy of an ATE steel caliper that was used on virtually every European make sedan and sports car. Finally, virtually all modern calipers are all made of aluminum now as it's lighter and stronger and better suited for the application of being hung off a cars suspension. They're using computers now and... they're using aluminum to manufacture calipers. Some "slide rule" designs were ahead of their time (Porsche seems to be famous for this). QUOTE Brembo, Alcon, PFC, Wilwood, etc all spend huge amounts of resources on trying to make their calipers stiffer. Back it up. Can you tell me how you could possibly know these companies spend huge amounts of resources to make their calipers stiffer or is this a general claim? If I were to make a general claim it would be that their engineers look at the numbers I posted because modern (computer) design practices dictate the use of the "Yield Strength" figures. QUOTE All the brake companies will tell you the flex is in the caliper design, not the fasteners. Again, back it up. You've spoken to "All the brake companies"? I've searched for your "flex design" criteria. I think you're making general statements that people could easily confuse with facts and even those are wrong. E.G.: with 4 M8 fasteners running from the nose to back... the fasteners "definitely" do play a factor in flex or no flex. If the fasteners were made out of rubber; would the caliper flex? Aluminum? Now steel? Steel is used where it is needed in modern computer designed aluminum calipers. So Matt... are you worried about actual "Strength" or are you concerned that these will literally "Flex" their way off the car? Or is there another point that you feel needs to be made? |
Matt Romanowski |
Aug 17 2012, 09:28 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The Yield Strength of aluminum will always be the same regardless of the "caliper design". Now, let's get into real world observations: I've "NEVER" seen a broken aluminum caliper but I've seen "innumerable" steel calipers with mounting ears fractured off and sealing flanges fractured. Steel is much more brittle than aluminum. The aforementioned Brembos have been in use since the mid-70's and again, I've "never" seen one broken or fractured. Same material depth on the mounting ears and around the piston flanges. Again, an aluminum copy of an ATE steel caliper that was used on virtually every European make sedan and sports car. Finally, virtually all modern calipers are all made of aluminum now as it's lighter and stronger and better suited for the application of being hung off a cars suspension. They're using computers now and... they're using aluminum to manufacture calipers. Some "slide rule" designs were ahead of their time (Porsche seems to be famous for this). If you want to play armchair engineer, which aluminim alloy are you using. Blanket statements like "steel is much more brittle than alumimum" show that you haven't worked with many different aluminum alloys. Try bending 6061-T6 and see how it does? There is a lot of work that goes into alloying a metal and picking the correct one for the application. QUOTE Brembo, Alcon, PFC, Wilwood, etc all spend huge amounts of resources on trying to make their calipers stiffer. Back it up. Can you tell me how you could possibly know these companies spend huge amounts of resources to make their calipers stiffer or is this a general claim? If I were to make a general claim it would be that their engineers look at the numbers I posted because modern design practices dictate the use of the "Yield Strength" figures. I've spent probably 10 hours talking to brake caliper engineers from Wilwood, PFC, and Alcon about the merrits of different designs and caliper flex and strength. Or, if you would like, PFC will tell you at http://www.performancefriction.com/motorsp...e-calipers.aspx. Notice the number of times they tell you the calipers are forged and have gone through FEA analysis. Also notice that most new aluminum calipers have either a bridge bolt or an acutal part of the caliper body cross the pad area to hold the two halves from spreading. QUOTE All the brake companies will tell you the flex is in the caliper design, not the fasteners. Again, back it up. You've spoken to "All the brake companies"? I've searched for your "flex design" criteria. I think you're making general statements that people could easily confuse with facts and even those are wrong. E.G.: with 4 M8 fasteners running from the nose to back... the fasteners "definitely" do play a factor in flex or no flex. If the fasteners were made out of rubber; would the caliper flex? Aluminum? Now steel? Steel is used where it is needed in modern computer designed aluminum calipers. Most of the flex comes in the caliper material and design. Does some come from the fasterner? Sure. Is it the majority? No. Notice most new hi-pefrormance calipers are forged out of special alloys. They are also designed [i]to be made out of alimunim, not steel. So Matt... are you worried about actual "Strength" or are you concerned that these will literally "Flex" their way off the car? Or is there another point that you feel needs to be made? Neither. Will they be strong enough? Probably, but I don't know. Will the flex themselves off the car? Probably not, but I don't know. Do you? Did you test them? Do the engineering? After all, brakes aren't that imporotant. Maybe I wasn't clear in my original posts - will these flex and cause pedal feel problems? What will they do when they get hot? I'm sure you've come across the stories how the aluminum 911S calipers can be really spongy compared to the steel calipers. Wonder why? Also, if you would like to make attacks, I'm happy to talk to you about being an "internet racer." I'm happy to put my track experience up against anyone on this site. What's you're track experience? Or better, what's your engineering background? |
Lo-Fi Version | Time is now: 14th May 2024 - 06:34 PM |
