First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
Eric_Shea |
Aug 14 2012, 08:16 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The time has come. We are beginning to take pre-orders on the 914-6 rear calipers.
As you know, us 914 owners have long been looking for a solution to a properly biased brake system. The fronts have been the easy part, bolt on a pair of Brembo's ...or a 3.5" 911 front suspension and you would have your choice of larger calipers with 48mm pistons up front. But, what about the rears? You need a 38mm piston to give you the correct bias. For 914 owners that meant a long and winding road of searching for the proper solution which usually boiled down to two things; uber-rare (and uber-expensive) original 914-6 calipers or 911 rear calipers and a confusing handbrake assembly or, worse yet, 911 rear calipers and no handbrake solution. Well, you're looking at the true bolt on solution. Aluminum castings of the famous 914-6 rear calipers. Final weigh-in has yet to be established but, we think we'll be under 3lbs each with the aluminum pistons. These simply bolt on and use stock handbrake cables and parts. Larger pistons and larger pads make this the prefect rear caliper solution for Brembo bolt-ons and S-Caliper or A-Caliper upgrades. What you are looking at is a raw alloy assembled prototype prior to anodizing. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953789.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953790.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1344953790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953791.4.jpg) |
Eric_Shea |
Aug 21 2012, 07:25 AM
We can rebuild anything.
Steel isn't difficult to machine. You're still talking about good money for bad. QUOTE If you do not offer the machining ....... then ...... if I were to send you my pair of steel 1968 ATE 'M' calipers already machined at the mounting flange, would you be able to rebuild them? Maybe I can search for someone with a larger mill ... I take it you are talking about machining a solid rotor (68) m-caliper to fit on a late model 914 strut. After reviewing all of these options many times, I fail to see the value in that. Here's why: 1. Exact same pad size as a 914 caliper. 2. Same solid rotor will not shed heat any faster. 3. Need to machine 914 rotor/hubs to 5-lug every time you need a new ones (if that's what you're doing). 4. Larger 48mm piston will throw off the bias unless you go with a rather expensive rear solution, but then... ....again, why not put that money toward 911 struts that offer a real benifit (larger bearings, lightweight hub assembly with vented rotors that weigh the same as a solid 914 rotor/hub assembly)? They simply bolt to your a-arms. Or - just stick with the stock late model 914 front caliper. It has thicker pads anyway. So... Rear Calipers. Should go into final machine consulting today. I hope to have final pricing this week as well. |
Lo-Fi Version | Time is now: 15th May 2024 - 06:59 AM |
