First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
ConeDodger |
Jun 17 2019, 06:41 PM
Apex killer! Group: Members Posts: 23,567 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I don’t know the whole story but I don’t think they were cost effective for Eric to keep making. 914rubber had a steel version made and I think it was the same deal. Machining a small quantity was pricey. They were always intended to be a limited run. I bought the last set and that is closed down... |
ConeDodger |
Jun 17 2019, 06:52 PM
I am looking for a set of rears to match my S calipers up front. Does anyone have a set for sale? Tyler Are you rich Tyler? It was an incredible collaboration for Eric Shea and Mark Whitesell to get together and produce the limited run they did, I don’t think Eric has time for that again, his business has a three year supply of restoration customers. If you’ve got a trunk full of money, you might talk someone who has a set into parting with them. But otherwise, you should consider other options. Here in this pic are my Brembo/Ferrari/Alfa front brakes. Alloy, polished and clear coated. Not impossible to find, but pretty darned difficult. Attached image(s) |
rgalla9146 |
Jun 17 2019, 07:26 PM
I am looking for a set of rears to match my S calipers up front. Does anyone have a set for sale? Tyler Are you rich Tyler? It was an incredible collaboration for Eric Shea and Mark Whitesell to get together and produce the limited run they did, I don’t think Eric has time for that again, his business has a three year supply of restoration customers. If you’ve got a trunk full of money, you might talk someone who has a set into parting with them. But otherwise, you should consider other options. Here in this pic are my Brembo/Ferrari/Alfa front brakes. Alloy, polished and clear coated. Not impossible to find, but pretty darned difficult. ....... but the discussion is alloy rears (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
I have PMB V-calipers, stock /4 calipers with a spacer between the halves and shims (thin washers) between the caliper and the trailing arm mount. Uses 911 vented rears OD cut down 4mm.
I don't see these anymore, IIRC Eric couldn't find a supply for the longer bolts and the longer pad hardware (pins and springs). (IMG:http://www.914world.com/bbs2/uploads/post-26-1496897462.jpg) |
ConeDodger |
Jun 17 2019, 11:18 PM
I am looking for a set of rears to match my S calipers up front. Does anyone have a set for sale? Tyler Are you rich Tyler? It was an incredible collaboration for Eric Shea and Mark Whitesell to get together and produce the limited run they did, I don’t think Eric has time for that again, his business has a three year supply of restoration customers. If you’ve got a trunk full of money, you might talk someone who has a set into parting with them. But otherwise, you should consider other options. Here in this pic are my Brembo/Ferrari/Alfa front brakes. Alloy, polished and clear coated. Not impossible to find, but pretty darned difficult. ....... but the discussion is alloy rears (IMG:style_emoticons/default/confused24.gif) Well, I have front and rear alloys. My rears are the last set of PMB alloy rears sold. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:50 PM |
