compresion problem? |
dirk9141973 |
Aug 16 2012, 03:41 PM
Unregistered |
Working on engine start up after rebuild (2056) and maybe have 10 minutes run time. (No load still on jack stands) Noticed that something was out not much compression through cylinder #2. Shut it down no bad sounds or smoke everthing turns over smoth. compresson test # 1 120 # 2 65 # 3 118 # 4 120 Can the valve settings be so far off to get low compression? What should I try ??
Lo-Fi Version | Time is now: 19th May 2024 - 09:17 AM |
