dirk9141973
Aug 16 2012, 03:41 PM
Working on engine start up after rebuild (2056) and maybe have 10 minutes run time. (No load still on jack stands) Noticed that something was out not much compression through cylinder #2. Shut it down no bad sounds or smoke everthing turns over smoth. compresson test # 1 120 # 2 65 # 3 118 # 4 120 Can the valve settings be so far off to get low compression? What should I try ??
benalishhero
Aug 16 2012, 04:17 PM
Yes improper valve adjustment can cause improper compression. Don't burn a valve.....
timothy_nd28
Aug 16 2012, 05:26 PM
A silly question, are the piston rings for #2 staggered?
brant
Aug 16 2012, 05:44 PM
adjust the valves cold and retest...
it could be possible to break a ring during install ?
VaccaRabite
Aug 16 2012, 06:45 PM
Check valves first.
If that does not bring it up, do a leakdown test and listen to where the air is escaping.
Zach
benalishhero
Aug 16 2012, 06:49 PM
dirk9141973
Aug 18 2012, 12:04 PM
Well good news no burnt valves but valve train was a mess !! All fixable ! 2 studs nuts were in valve cover 2 were striped out but not in head the hold down blocks. Removed all (8) studs and replaces with new HD larger studs they came with cam kit. I think the problem valves toooo tight and new HD valve springs? Has anyone had this problem?
