Dash Brake Light, Always On And Buzzing |
minnesota loon |
Aug 19 2012, 09:19 AM
Member Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
My brake warning light is always on. Buzzer also on. When I use the turn signals it flashes with them. This first happened when I changed seats in the car. the flasher under the passenger seat is loose and just laying there. Any thoughts? I have tried to reset the brake warning system but it does not respond. Can I unhook it?
Mike Bellis |
Aug 19 2012, 09:45 AM
You can disconnect the relay under the passenger seat but you have to connect the 2 big yellow wire together. These are the starter in/out wires. Originally designed to prevent the starting if the seat belts were not fastened.
etcmss |
Aug 19 2012, 10:13 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
is the emergency brake switch stuck or not depressed? this usually causes the brake light to flash. (brake handle must be down on switch.)(you already knew that right?)
Gary |
aharder |
Aug 19 2012, 10:41 AM
Advanced Member Group: Members Posts: 4,402 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
If you turn on your hazard lights doe's it stop buzzing?
aharder |
I have the same issue with Mine.
swl |
Aug 19 2012, 10:55 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Buzzer also on. When I use the turn signals it flashes with them. This first happened when I changed seats in the car. no direct experience on the buzzer part but given you have just changed seats I wonder if the pressure sensor 'passenger seat is occupied but the seatbelt isn't fastened' is showing the seat as occupied. Try plugging the seatbelt in? Where I have had experience is on the drivers side. The brake switch is contact to ground. So if there is a pinch on the wire to the switch that breaks the insulation you will get the flasher going off. Mine got pinched in the seat rail. |
minnesota loon |
Aug 20 2012, 06:49 AM
I removed the bulb from the gauge.
Lo-Fi Version | Time is now: 28th May 2024 - 07:31 PM |
