QUOTE(minnesota loon @ Aug 19 2012, 11:19 AM)
Buzzer also on. When I use the turn signals it flashes with them. This first happened when I changed seats in the car.
no direct experience on the buzzer part but given you have just changed seats I wonder if the pressure sensor 'passenger seat is occupied but the seatbelt isn't fastened' is showing the seat as occupied. Try plugging the seatbelt in?
Where I have had experience is on the drivers side. The brake switch is contact to ground. So if there is a pinch on the wire to the switch that breaks the insulation you will get the flasher going off. Mine got pinched in the seat rail.
