WTB: 2.0 Engine tin |
billh1963 |
Aug 20 2012, 01:09 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Well, upon further inspection I think I need to replace my tin. The tin I have on my '76 2.0 was cut for A/C and has been generally abused.
Looking for a complete set of tin (thanks to JRust I do not need the tin between the push rod tubes and the cylinders). Let me know what you have! |
TheCabinetmaker |
Aug 20 2012, 02:33 PM
I should have everything you need Bill. When you say all pieces, are you including the ones that go under the top tins in the front and back? Or just the front under the fan(2). 2 above the cylinders, and the rear?
billh1963 |
Aug 20 2012, 02:43 PM
I should have everything you need Bill. When you say all pieces, are you including the ones that go under the top tins in the front and back? Or just the front under the fan(2). 2 above the cylinders, and the rear? I would like all pieces except for the flat pieces that go under the cylinders (above the push rod tubes). Some of my tin is okay; however, much of the top tin on the passenger side was butchered from the a/c installation. |
Valy |
Aug 23 2012, 11:53 AM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Lo-Fi Version | Time is now: 25th May 2024 - 10:49 AM |
