opening front trunk, cable may be rusted shut! |
Noodles |
Aug 24 2012, 11:13 AM
Newbie Group: Members Posts: 37 Joined: 17-July 12 From: Seattle,Wa Member No.: 14,688 Region Association: Pacific Northwest |
Is there any tricks to getting the front trunk open without the cable, my parts car front trunk is stuck closed, pulled lever and it just wont budge, got it to move very very slightly but just can't seem to get it to pop. I do have it up maybe quarter inch so not sure if i can get to the latch with something to pop it open.
Any tips would be much appreciated, have pulled so hard on the handle i'm waiting for it to snap (IMG:style_emoticons/default/headbang.gif) |
Eric_Shea |
Aug 24 2012, 11:22 AM
Off comes the front bumper
SLITS |
Aug 24 2012, 11:29 AM
Remove the front bumper. You will find a little hole in the cowl in which you can insert a screwdriver and pop the mechanism open.
Chit ... Erc was faster. |
Eric_Shea |
Aug 24 2012, 11:34 AM
That's what she said... (IMG:style_emoticons/default/huh.gif)
hot_shoe914 |
Aug 24 2012, 12:04 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Get somebody to push down on it while you pull the cable.
Noodles |
Aug 24 2012, 12:52 PM
rgalla9146 |
Aug 24 2012, 06:36 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Get somebody to push down on it while you pull the cable. Oooh I'll have to try that, thanks for the quick replys I was hoping it would be nice and easy. with the hood open you can now fix the inop pull wire or sticky latch. Disconnect pull wire from latch. Detach white plastic sleeve from latch and locating tabs. Lift sleeve skyward and flood tube with your favorite snake oil. When the PB Blaster has stained your carpet the cable is ready to move. Slide tube off wire by pulling away from fixed metal guide tube in cowl area. Remove rust from pull wire with sand paper or whatever. Lubricate liberally as you slide the tube back over the wire. Check operation of latch by closing with the tip of a phillips screwdriver and releasing with a plier. If sticky douse with WD40 till the spare tire floats. When wire and latch are free, reassemble and adjust. WALLA ! |
Lennies914 |
Aug 24 2012, 06:43 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Get somebody to push down on it while you pull the cable. Oooh I'll have to try that, thanks for the quick replys I was hoping it would be nice and easy. with the hood open you can now fix the inop pull wire or sticky latch. Disconnect pull wire from latch. Detach white plastic sleeve from latch and locating tabs. Lift sleeve skyward and flood tube with your favorite snake oil. When the PB Blaster has stained your carpet the cable is ready to move. Slide tube off wire by pulling away from fixed metal guide tube in cowl area. Remove rust from pull wire with sand paper or whatever. Lubricate liberally as you slide the tube back over the wire. Check operation of latch by closing with the tip of a phillips screwdriver and releasing with a plier. If sticky douse with WD40 till the spare tire floats. When wire and latch are free, reassemble and adjust. WALLA ! Or get a "trunk-monkey" (IMG:style_emoticons/default/biggrin.gif) |
hot_shoe914 |
Aug 24 2012, 08:34 PM
Get somebody to push down on it while you pull the cable. Oooh I'll have to try that, thanks for the quick replys I was hoping it would be nice and easy. with the hood open you can now fix the inop pull wire or sticky latch. Disconnect pull wire from latch. Detach white plastic sleeve from latch and locating tabs. Lift sleeve skyward and flood tube with your favorite snake oil. When the PB Blaster has stained your carpet the cable is ready to move. Slide tube off wire by pulling away from fixed metal guide tube in cowl area. Remove rust from pull wire with sand paper or whatever. Lubricate liberally as you slide the tube back over the wire. Check operation of latch by closing with the tip of a phillips screwdriver and releasing with a plier. If sticky douse with WD40 till the spare tire floats. When wire and latch are free, reassemble and adjust. WALLA ! Or get a "trunk-monkey" (IMG:style_emoticons/default/biggrin.gif) Paging Clay! |
Valy |
Aug 24 2012, 10:00 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
One more thing to check when repairing is the jacket stopper where the plastic jacket slides into the metal one (near the brake fluid reservoir ). Make sure the stopper doesn't slide on the jacket or else you won't open the trunk. I tried gluing it back but yesterday I had to drop the bumper again. This time I placed a hose clamp over it to make sure it stays there.
Lo-Fi Version | Time is now: 16th May 2024 - 05:21 PM |
