914-6 RRC 2013 Tune Up, 914-6 RRC 2013 Tune Up |
brant |
Aug 27 2012, 08:50 AM
914 Wizard Group: Members Posts: 11,637 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
do you still have the old parts
did you guys put hydraulic tensioners in? any desire to sell the solid tensioners? brant |
sixnotfour |
Aug 27 2012, 09:02 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
What is making the flywheel BAD ?
teeth ? wear on clutch surface ? |
SLITS |
Aug 27 2012, 09:16 AM
Since it is CIS, the cams permissible are very limited. I believe the upgrade is the 964 cam profile which will net about 10 hp gain. Other gains can be had by raising the compression ratio. CIS limits the gains, but retains the fuel mileage.
The mechanical tensioners would have been ideal to leave in. I don't care what others say, I have them in mine. The stock or "upgrade" Carrera tensioners can fail with catastrophic results. Adjusting mechanicals every 10K is not a big deal. Oh, the distributor you have was used on the 09/1971 - 08/1973 2.3L 911S engine (911/53 & 911/63) I have a rebuilt 0 231 169 008 (09/73 - 06/77) 911/911S 2.7L but it is missing the cap clips (yours would work) in case you get crazy and want to change it. Oh well, that's my opinion anyway! |
map |
Aug 27 2012, 12:15 PM
Pieper Group: Members Posts: 89 Joined: 29-May 09 From: Manitou Springs CO Member No.: 10,420 Region Association: Rocky Mountains |
What is making the flywheel BAD ? teeth ? wear on clutch surface ? The flywheel is really old. Witness the difficulty reading the part number. Also there was a onetime event that scored the starter ring. I was thinking of replacing it with an aluminum one. The clutch plate has less than 20K. For now, all of the parts will go back on the car. Pieper |
map |
Aug 27 2012, 12:17 PM
Thanks everyone for helping identify what I have and need.
You too Kevin! Pieper |
SLITS |
Aug 27 2012, 01:22 PM
What is making the flywheel BAD ? teeth ? wear on clutch surface ? The flywheel is really old. Witness the difficulty reading the part number. Also there was a onetime event that scored the starter ring. I was thinking of replacing it with an aluminum one. The clutch plate has less than 20K. For now, all of the parts will go back on the car. Pieper The ring gear can be machined off and a replacement welded on. I've had it done by a machine shop myself. Just because the part number is obscure doesn't mean it bads |
sixnotfour |
Aug 27 2012, 01:37 PM
Dont buy an aluminum one ,About 2-3 lbs can be removed easily and makes a difference.
as long as all the teeth are solid, a bit of the corner knock off them is common. If you really want to spend the money ?? |
map |
Aug 27 2012, 06:10 PM
Are these the correct flywheel bolts?
http://www.pelicanparts.com/cgi-bin/smart/...%37%32%29%20%20 Pieper |
brant |
Aug 27 2012, 08:39 PM
hmmm...
that says 914/6 I've bought the early 911 ones before with a different part number I don't understand why the real 914/6 ones would interchange with late 2.7 cars... is it a typo? now I'm not sure..... brant |
SLITS |
Aug 27 2012, 08:50 PM
majkos |
Aug 27 2012, 10:21 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
majkos |
Aug 27 2012, 10:23 PM
majkos |
Aug 27 2012, 10:25 PM
sixnotfour |
Aug 27 2012, 11:22 PM
was there a 6 hole washer under the flywheel bolt heads and the flywheel ?
majkos |
Aug 28 2012, 08:48 AM
yup
I tried to find it, and send you a pic. but it seems AWOL at the moment. |
majkos |
Aug 28 2012, 09:15 AM
anybody(in town) has the correct flywheel bolts?
Or know where I can get them, today? |
Scott S |
Aug 28 2012, 09:53 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Try these:
Storz Garage: 3-333-1911 Eisenbuds: 3-825-0322 3R: 3-781-0774 Stevinson:3-794-3550 or (even though they SUCK) Prestige: 3-238-8101 |
map |
Aug 28 2012, 10:18 AM
majkos |
Aug 28 2012, 10:23 AM
Yup (IMG:style_emoticons/default/mad.gif)
SLITS |
Aug 28 2012, 10:28 AM
If you had looked on ClubNARP, I gave you the link to the correct bolts on Pelican. I am sure they would have swapped for the correct ones. Call Glenn @ extension 240 and I am sure he will get it corrected for you. You'll just need to ship the Clay Perrine bolts back.
The shorter bolts are for the '70 & up 225 mm FLAT flywheel with bolt on starter ring. The longer are for the '65 - '69 215 mm flywheel that also uses the spacer between the bolts and the flywheel. MAKE SURE YOU HAVE THE SPACER |
Lo-Fi Version | Time is now: 6th June 2024 - 02:21 PM |
