914-6 RRC 2013 Tune Up, 914-6 RRC 2013 Tune Up |
SLITS |
Oct 25 2012, 01:37 PM
While it may be expensive, if the follower is that loud pay them to adjust the valves.
A loose valve is far better than a tight valve. |
map |
Oct 25 2012, 05:16 PM
Pieper Group: Members Posts: 89 Joined: 29-May 09 From: Manitou Springs CO Member No.: 10,420 Region Association: Rocky Mountains |
Broken or bent exhaust valve on the left side.
(IMG:style_emoticons/default/stromberg.gif) I'll be in my room... Pieper |
majkos |
Oct 25 2012, 05:23 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Ferg |
Oct 25 2012, 08:43 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Kirmizi |
Oct 25 2012, 09:43 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Gint |
Oct 26 2012, 06:12 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Yikes... Sorry Mike.
SLITS |
Oct 26 2012, 06:52 AM
(IMG:style_emoticons/default/sad.gif)
If you need a head or 3, let me know. I believe I have a setup (heads & cam tower still bolted together) for a 2.7L. |
Scott S |
Oct 26 2012, 10:10 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
cr@p. I am sorry - that really stinks.
Was the engine noisey before you guys did all of the work? |
brant |
Oct 26 2012, 10:29 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Dang. I'm so sorry. It is something that can be repaired at least. Usually the one head can be repaired and the bank put back. (Checking the cam timing). So sorry.
sixnotfour |
Oct 26 2012, 11:02 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
put a chopstick into the spark plug hole and turn the motor over .
Its along shot , but maybe you will bend it back straight.....yup yup great idea..... (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) Bad News.....at least now you have all winter (IMG:style_emoticons/default/dry.gif) |
RonD |
Oct 26 2012, 11:31 AM
Ron Diederichsen Group: Members Posts: 97 Joined: 2-July 04 From: Boulder, CO Member No.: 2,286 Region Association: None |
I'm afraid I am all too familar with your pain. Sorry to hear about this. Kind of fits the gloomy snowy weather we are having right now.
Don't want to drive in weather like this anyway so at least we got a few months to get them fixed and ready for next season. |
SLITS |
Oct 26 2012, 11:56 AM
Dang. I'm so sorry. It is something that can be repaired at least. Usually the one head can be repaired and the bank put back. (Checking the cam timing). So sorry. Brant, Pieper / Kevin are newbies to a six so you have to explain that the heads are done in 3s. They have to be matched for height so that the cam carrier will sit flat. That is why I offered a set of 3 still bolted to the cam carrier. I suppose they could do just one because it is already matched to the other two. |
brant |
Oct 26 2012, 01:04 PM
I guess my hope was that the original head can be reused and the height match still matches....
hopefully a new valve and clean up will do it. good point though.. if you can't reuse one head, you have to find a replacement that is height matched (hard to do) it really sounds like the cam timing was off enough that it kissed some valves... hopefully given that it ran only a little in the jacks shop.... it didn't over heat or hopefully didn't hit hard enough to damage pistons/rods/etc... (bent is much better than broken... crossing my fingers) so one or some, new valves and some clean up could be an option still. brant |
sixnotfour |
Oct 26 2012, 01:15 PM
(IMG:style_emoticons/default/agree.gif) probably got adjusted wrong and banged the piston.
new valve or reground used and a lap , It will be fine....just a Pit Stop. |
map |
Aug 30 2013, 06:22 AM
Hopefully everyone understands why this thread has been dark for so long. It has taken some time to get the car back to its prior level of performance. After the valve job, I had to rebuild the rear accelerator cable mount as the custom parts disappeared in the repair process. After that, the car was still running poorly because some of the plug wire wouldn't stay connected and the ground to the fuel pump was faulty, creating fuel pressure issues.
Now the car is running great and I am back in love. Here's a recap of what was done as part of this 13 month tuneup. Transmission Rebuild Air Filter Ditributor (vacuum advance on the old one was broken) Distributor Cap Rotor Fuel Filter Oil Pressure Switch Oil Pressure Sending Unit (no guage yet) Chain Tensioner Update Pertronix Valve Job Crank Pulley (the old one was for an AC equipped car) Plug Wires Spark plugs I guess I knew what I was doing when I labeled this thread "914-6 RRC 2013 Tune Up." Diane, the yellow 914 and I will be in Durango next week and I will be smiling again. Thanks for all the help and support Kevin and I received. This is a fantastically knowledgeable and helpful community. Pieper |
Eric_Shea |
Aug 30 2013, 07:10 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Scott, thanks for pointing out which tranny you're talking about there. (IMG:style_emoticons/default/wink.gif)
all of the 914 trannys need the 64-69 flywheel (6 bolt) just buy a 914 clutch kit (the 6 cylinder ones are probably all that is sold now, they have more springs for less stutter as you start out in 1st gear) This. from the pics, that is the correct flywheel from an early 911/914-6. Did you get new bolts? I have a huge binder of info (all printed from either this site or Pelican) from doing my conversion. Would you like to borrow it? I can pick it up on Thursday and drop it off on friday. Let me know. |
Eric_Shea |
Aug 30 2013, 07:12 AM
Broken or bent exhaust valve on the left side. (IMG:style_emoticons/default/stromberg.gif) I'll be in my room... Pieper Now I don't feel so bad. But, I feels bad for you. (IMG:style_emoticons/default/sad.gif). Glad you got it running! |
sixnotfour |
Aug 30 2013, 07:59 AM
Oh Boy another yellow six RRC 2013
map |
Aug 30 2013, 07:04 PM
Lo-Fi Version | Time is now: 6th June 2024 - 08:31 AM |
