| VaccaRabite |
Aug 27 2012, 12:39 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,952 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Can you flat tow a 914 w/o the engine/transmission installed? How would you keep the axles from flopping around? You could pull them, but I think thats certain death for the bearings.
Zach |
| audio_file |
Aug 27 2012, 12:42 PM
Member ![]() ![]() Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
I used to tow old subies with no engine (or rear diff) and would just use a thick zip tie to hold up the axle, never had one wear thru, and didn't damage the axle.... Ymmv
| Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,903 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Hey Zack as long as you leave the stubs I'm the hub your good. Just unbolt the cv from the stub and get the axles off.
| JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I'd remove the axles. I don't think it will kill the bearings. I've got a trailer thats been running for years that way with no problem. Less weight yes but probably not that different than a car with no drivetrain. I probably wouldn't go across country like that. A couple hundred miles I wouldn't sweat it (IMG:style_emoticons/default/confused24.gif)
| jimkelly |
Aug 27 2012, 12:54 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
can the cv's on the swing arm side be removed without pulling stub axle?
| JRust |
Aug 27 2012, 01:14 PM
can the cv's on the swing arm side be removed without pulling stub axle? yep! I do it all the time. So much nicer having them out of the way when dropping the motor & tranny (IMG:style_emoticons/default/biggrin.gif) |
| Mark Henry |
Aug 27 2012, 02:03 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I don't know where this tale of "flat towing without an engine/trans will ruin your bearings" got started but it's wrong.
My guess is some yahoo flat towed a 914 with the axles on and destroyed more than just his bearings.... then told everyone you can't do it. Or maybe the stubs and hubs were not bolted together... or maybe his trailing arm broke off because it was rusted out... You do have to leave the hub bolted to the stub. The trailing arm mounts would have to be in good condition. I would never tow a 914 with just the axles on, ever, no exceptions. Removing the CV's, although may be a PITA on a 914, it will not ruin your wheel bearings. You can then tow it no problem. |
| type47 |
Aug 27 2012, 02:48 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Whoops, posted bad advice (IMG:style_emoticons/default/slap.gif)
| dlee6204 |
Aug 27 2012, 03:00 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
| IronHillRestorations |
Aug 27 2012, 03:22 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
There've been a few guys that had problems flat towing a car with the stub axles removed, which you can't do.
If you try and tow the car with the half shafts supported by zip ties, you'll get about a mile and a half before you have problems. |
| ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Agreed. Its not sturdy enough and the center assembly doesn't have bearings needed for high speed rotation. Just remove the halfshafts and leave the stubs installed. |
| VaccaRabite |
Aug 27 2012, 03:43 PM
Okay. Half shafts!
Plas76targa: get those tow bar mounts on your 911 or I am going to tow my 914 to Scott's instead. I'm call'n you out, Mr P. (IMG:style_emoticons/default/laugh.gif) Zach |
| mepstein |
Aug 27 2012, 03:53 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,016 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Okay. Half shafts! Plas76targa: get those tow bar mounts on your 911 or I am going to tow my 914 to Scott's instead. I'm call'n you out, Mr P. (IMG:style_emoticons/default/laugh.gif) Zach If Matt needs a tow to Scotty's, I can help out. |
| plas76targa |
Aug 27 2012, 07:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Okay. Half shafts! Plas76targa: get those tow bar mounts on your 911 or I am going to tow my 914 to Scott's instead. I'm call'n you out, Mr P. (IMG:style_emoticons/default/laugh.gif) Zach Damn, you read posts fast! The shellange is on! if you tow your 914 then i'll drag the 911 behind the Enclave. I should have the towing package installed by then. |
| VaccaRabite |
Aug 27 2012, 07:09 PM
Matt, the 911 has priority. If I bring the 914 I'll be tempted to work on it instead of having a party. I'd rather bring down the 911.
| hot_shoe914 |
Aug 27 2012, 07:12 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
If Zach can get his 914 to Scotty's party I am bringing him a motor that is basically plug and play that all the drunk people can install into his car.
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/drunk.gif) ![]() |
| scotty b |
Aug 27 2012, 07:32 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Okay. Half shafts! Plas76targa: get those tow bar mounts on your 911 or I am going to tow my 914 to Scott's instead. Zach (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/WTF.gif) is this aboot ? (IMG:style_emoticons/default/confused24.gif) |
| VaccaRabite |
Aug 27 2012, 07:43 PM
Dons fault. He put this hair brained idea in my head.
Zach |
| scotty b |
Aug 27 2012, 07:56 PM
Then Donald can start paying my shop insurance when they find out customers have been working on their own cars here and drop my policy (IMG:style_emoticons/default/dry.gif)
| VaccaRabite |
Aug 27 2012, 08:08 PM
Ahh. So maybe not the best idea then. Well, I'll just have to leave my car home and enjoy the party then.
Good. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th November 2026 - 04:06 AM |
