Quick help-Brake lights stay on-, When the headlights are on |
PBC914 |
Aug 27 2012, 03:43 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
Is this an indication of a bad relay? If so which one?
Thanks! |
Aug 27 2012, 03:47 PM
Nope. It's most likely a mis-wiring at the taillight buckets, or having the wrong bulbs in the wrong sockets.
Unless the brake lights are on any time the ignition switch is on--in that case, you put the washer on the brake pedal pushrod on the wrong side of the lever on the brake light switch. --DD |
Valy |
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Bad ground at the tail lights.
Mike Bellis |
Aug 27 2012, 03:53 PM
Courtesy of Jeff Bowlsby...
PBC914 |
Aug 27 2012, 04:08 PM
What is strange is that they were working before I went out one night and was turning the lights on and off for my kids. I didn't change anything. I'll check the ground-thanks everyone. Any other ideas welcome!
Also, I noticed that with the ignition off, and the lights turned on the brake lights are on. If I step on the brakes, it makes the gas needle move to position, and the voltmeter moves to on. |
PBC914 |
Aug 27 2012, 09:04 PM
I double checked the connections on the rear lights, all terminals were clean and connected properly.
Could the headlight switch be the problem? |
Aug 27 2012, 09:07 PM
The latter sounds similar to some behavior we see when fuse #8 or #9 pops.
--DD |
Lo-Fi Version | Time is now: 15th May 2024 - 10:40 AM |
