PBC914
Aug 27 2012, 03:43 PM
Is this an indication of a bad relay? If so which one?
Thanks!
Dave_Darling
Aug 27 2012, 03:47 PM
Nope. It's most likely a mis-wiring at the taillight buckets, or having the wrong bulbs in the wrong sockets.
Unless the brake lights are on any time the ignition switch is on--in that case, you put the washer on the brake pedal pushrod on the wrong side of the lever on the brake light switch.
--DD
Valy
Bad ground at the tail lights.
Mike Bellis
Aug 27 2012, 03:53 PM
Courtesy of Jeff Bowlsby...
PBC914
Aug 27 2012, 04:08 PM
What is strange is that they were working before I went out one night and was turning the lights on and off for my kids. I didn't change anything. I'll check the ground-thanks everyone. Any other ideas welcome!
Also, I noticed that with the ignition off, and the lights turned on the brake lights are on. If I step on the brakes, it makes the gas needle move to position, and the voltmeter moves to on.
PBC914
Aug 27 2012, 09:04 PM
I double checked the connections on the rear lights, all terminals were clean and connected properly.
Could the headlight switch be the problem?
Dave_Darling
Aug 27 2012, 09:07 PM
The latter sounds similar to some behavior we see when fuse #8 or #9 pops.
--DD
