| cal914 |
Aug 28 2012, 01:02 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
i have just bought my first 914 when i shut the doors it looks like it pushes the windshield pillar up slightly they have had new rubbers put on is this the cause or does the cat have a bit of sagging thanks brian
| chuckc |
Aug 28 2012, 01:10 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
i have just bought my first 914 when i shut the doors it looks like it pushes the windshield pillar up slightly they have had new rubbers put on is this the cause or does the cat have a bit of sagging thanks brian sounds like rust issues, check longs and hell hole. peace, Chuck |
| VaccaRabite |
Aug 28 2012, 05:39 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,817 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Cal, do not drive your car. It is likely rusted to the point of being unsafe.
You need to pull the rockers off the side of the car, pull the battery out and look under the battery and down towards the firewall. Clean all the leaves and dirt out and probe with a screwdriver. But if your car flexes when you shut the door, you probably have very serious rust issues and the car is unsafe. Please check it out. Sorry to be a downer. Zach |
| hot_shoe914 |
Aug 28 2012, 05:52 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Cal, do not drive your car. It is likely rusted to the point of being unsafe. You need to pull the rockers off the side of the car, pull the battery out and look under the battery and down towards the firewall. Clean all the leaves and dirt out and probe with a screwdriver. But if your car flexes when you shut the door, you probably have very serious rust issues and the car is unsafe. Please check it out. Sorry to be a downer. Zach They say Christine is unsafe but I still drive her anyway. (IMG:style_emoticons/default/driving.gif) |
| messix |
Aug 28 2012, 05:59 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
this just might be that over the years people have hung on the the windsheild header to pull them selves up and out of the car and have bent the header down a bit.
there is a test called "the big butt test" to check how bad the longs flex and that is to load a couple a big boys [southern style of big boys over 200lbs] in the car and see how bad the door gaps close up and see if you can shut the door or open the door with the big boys in there. |
| IronHillRestorations |
Aug 28 2012, 06:08 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,896 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
It's easier than that.
Measure the door gap at the top and bottom of the passenger door, back the right rear wheel up on a curb (right rear wheel only), measure the door gaps as well as open and close the passenger door. If the gaps move more than 1/8, you have problems. If you can't open or close the door, you have major problems. |
| Katmanken |
Aug 28 2012, 06:30 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
It's easier than that. Measure the door gap at the top and bottom of the passenger door, back the right rear wheel up on a curb (right rear wheel only), measure the door gaps as well as open and close the passenger door. If the gaps move more than 1/8, you have problems. If you can't open or close the door, you have major problems. He lives in England. That 1/8 inch is about 3.18 mm. Hope that helps. Ken |
| URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 129,949 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Buy her an underwire bra. (IMG:style_emoticons/default/av-943.gif)
| ruby914 |
Aug 28 2012, 07:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I thought you would have him drill holes in everything but the longs. (IMG:style_emoticons/default/biggrin.gif) |
| Mike Bellis |
Aug 28 2012, 07:51 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| VaccaRabite |
Aug 28 2012, 08:42 PM
It's easier than that. Measure the door gap at the top and bottom of the passenger door, back the right rear wheel up on a curb (right rear wheel only), measure the door gaps as well as open and close the passenger door. If the gaps move more than 1/8, you have problems. If you can't open or close the door, you have major problems. He lives in England. That 1/8 inch is about 3.18 mm. Hope that helps. Ken Err. If he's in England probably using the inch. We got it from them after all. |
| bulitt |
Aug 28 2012, 11:56 PM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Is there a way to adjust the vent windows up or down?
| PancakePorsche |
Aug 29 2012, 02:52 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
My 76 does the same since I replaced all the seals and my car is absolutely rust free. I minimized it by adjusting windows and vent window angle to set pre-load. Pillar deflects about 2mm forward.
| 914werke |
Aug 29 2012, 10:01 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,475 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
this just might be that over the years people have hung on the the windsheild header to pull them selves up and out of the car and have bent the header down a bit. QUOTE the windsheild header (IMG:style_emoticons/default/screwy.gif) I think you mean the A-Pillar |
| cal914 |
Aug 29 2012, 10:26 AM
this just might be that over the years people have hung on the the windsheild header to pull them selves up and out of the car and have bent the header down a bit. QUOTE the windsheild header (IMG:style_emoticons/default/screwy.gif) I think you mean the A-Pillarchecked the door gaps and they seem fine, checked underneath the floor area and that is rock solid as well .looked in the battery tray area and there was no sign of any rust so may be theres no sagging what do you guys think |
| VaccaRabite |
Aug 29 2012, 10:31 AM
This is great news!
| FourBlades |
Aug 29 2012, 12:40 PM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
I'd still take the rocker panels off and check that area. It has a tendency to collect dirt and could probably use a cleaning anyway. John |
| VaccaRabite |
Aug 29 2012, 04:06 PM
| monkeyboy |
Aug 29 2012, 04:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I have new rubber in my car. The window corners fit snug up against the seals. It's somewhat normal, but I would make sure that you do not have any sag issues.
| Mike Bellis |
Aug 29 2012, 06:58 PM
My tub is bent below the A pillar on both sides. The DAPO welded the cage and bracing too hot. This makes my wing window hit the A pillar when closing AND it looks like the doors sag slightly in the rear. I have no rust issues either.
The car was a purpose built race car at the time of the welding. It tracks straight and true. Handles perfect and predictable. I drive it and enjoy it. One day... I will cut the cage out and make it un-bent. Until then... I drive... Flat out... (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 7th December 2025 - 01:29 AM |
