> original temp gauge, is there a test to see if it is working
rgolia
post Aug 31 2012, 08:44 AM
GeoJoe
My temp gauge doesn't move. I installed a new sender and still no movement. It does move (just a little) when the ignition is turned on so it is getting power.
SLITS
post Aug 31 2012, 09:20 AM
"This Utah shit is HARSH!"
With power on to gauge, ground the sender wire and it should move full scale.
Do you have a ground wire connected to the gauge itself?
rgolia
post Aug 31 2012, 11:35 AM
GeoJoe
I will try that test...thanks. The original 3 pong connector is how it is attached.
rgolia
post Oct 1 2012, 01:04 PM
GeoJoe
Did the test and the gauge works. The wire to the sender was faulty. Installed a new sender wire. Now that the gauge works, is there a way to get more fluctuation out of it. It seems to stay in the very low range regardless of driving conditions.
timothy_nd28
post Oct 1 2012, 01:12 PM
you could lean out your motor
damesandhotrods
post Oct 1 2012, 02:25 PM
QUOTE(rgolia @ Oct 1 2012, 12:04 PM) *
When I was in Portland Oregon, my temperature gauge never moved, I was beginning to suspect something was wrong with it. But once I moved to California I found it worked normally.
post Oct 1 2012, 03:45 PM
are your sender and gage a matched pair. look on the sender, it is stamped with it's range on the side of the sender.
- Lo-Fi Version Time is now: 14th April 2026 - 01:57 AM
