| Elliot Cannon |
Aug 31 2012, 06:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I just wired up these driving lights. I used a relay. Do I need to install an inline fuze? If so should it be between the battery and the relay? Or between the relay and the lights?
Cheers, Elliot PS The one on the left isn't crooked anymore. (IMG:style_emoticons/default/laugh.gif) Attached image(s)
| SirAndy |
Aug 31 2012, 06:25 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,562 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If so should it be between the battery and the relay? Or between the relay and the lights? Battery to relay. The reason to use a relay in the first place is the fact that the relay trigger current is very low. You'd run that off one of the existing fuses anyways. So you want to fuse the 12V supply from the battery to the relay/lights. (IMG:style_emoticons/default/popcorn[1].gif) |
| toolguy |
Aug 31 2012, 06:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
you want to fuse the power lead from the battery that goes through the relay and on to the lights. . fusing the battery lead that energizes the relay itself will offer no protection if you have a ground on the wire to the lights. . maybe just semantics but rather be clear about it. .
| 76-914 |
Aug 31 2012, 07:08 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Hmmm, let's see. Two lights (IMG:style_emoticons/default/poke.gif) Would that be one or two trips to the EM. (IMG:style_emoticons/default/biggrin.gif)
| Mike Bellis |
Aug 31 2012, 07:39 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
The fuse should be within 18" of the battery for safety.
| swl |
Sep 2 2012, 11:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
The fuse should be within 18" of the battery for safety. I agree. The closer to the power source the better. Tom has done a lot of thinking about upgrading of fusing. Came up with a pretty slick design if you really want to get into protecting your electrical system. http://www.914world.com/bbs2/index.php?showtopic=141317 |
Lo-Fi Version | Time is now: 14th November 2026 - 01:54 PM |
