Full Version: Help with electrical
Elliot Cannon
I just wired up these driving lights. I used a relay. Do I need to install an inline fuze? If so should it be between the battery and the relay? Or between the relay and the lights?
Cheers, Elliot
QUOTE(Elliot Cannon @ Aug 31 2012, 05:22 PM) *
Battery to relay.
The reason to use a relay in the first place is the fact that the relay trigger current is very low.
You'd run that off one of the existing fuses anyways.
So you want to fuse the 12V supply from the battery to the relay/lights.
toolguy
you want to fuse the power lead from the battery that goes through the relay and on to the lights. . fusing the battery lead that energizes the relay itself will offer no protection if you have a ground on the wire to the lights. . maybe just semantics but rather be clear about it. .
76-914
Hmmm, let's see. Two lights poke.gif Would that be one or two trips to the EM. biggrin.gif
Mike Bellis
The fuse should be within 18" of the battery for safety.
swl
QUOTE(kg6dxn @ Aug 31 2012, 09:39 PM) *
I agree. The closer to the power source the better.
Tom has done a lot of thinking about upgrading of fusing. Came up with a pretty slick design if you really want to get into protecting your electrical system.
http://www.914world.com/bbs2/index.php?showtopic=141317
