Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
Michelj13 |
Jan 21 2013, 07:34 PM
I had the whole day from 8 am to 5 pm to work on my project. I got the manifolds, TB, and all the wiring done.
Well, the engine started right up and all sensors appeared to be reading something. However, after the initial start up, the revs went past 4k before I turned off the ignition. I discovered the TPS was wired incorrectly. I fixed that, calibrated the TPS and the engine started up again. The idle then settled at 2600. I disconnected my fidle valve (it is normally closed), reduced the advance in the table and now idle is about 1200. TB is closed, so not sure where air is coming from. Also, it appears the engine speed does not change when I disconnect the #4 ignition coil and injector. I will need to check these. Anyway, I ran out of gas, losing my sunlight> It was time to stop, and clean up. It really was a Good Day! (IMG:style_emoticons/default/smile.gif) I bought the full version of TS back in Jan 2012. Does it expire? I would appreciate any help in progressing from this point. Yeh me (IMG:style_emoticons/default/beer3.gif) Photos coming soon. Michel |
wndsrfr |
Jan 21 2013, 09:00 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I had the whole day from 8 am to 5 pm to work on my project. I got the manifolds, TB, and all the wiring done. Well, the engine started right up and all sensors appeared to be reading something. However, after the initial start up, the revs went past 4k before I turned off the ignition. I discovered the TPS was wired incorrectly. I fixed that, calibrated the TPS and the engine started up again. The idle then settled at 2600. I disconnected my fidle valve (it is normally closed), reduced the advance in the table and now idle is about 1200. TB is closed, so not sure where air is coming from. Also, it appears the engine speed does not change when I disconnect the #4 ignition coil and injector. I will need to check these. Anyway, I ran out of gas, losing my sunlight> It was time to stop, and clean up. It really was a Good Day! (IMG:style_emoticons/default/smile.gif) I bought the full version of TS back in Jan 2012. Does it expire? I would appreciate any help in progressing from this point. Yeh me (IMG:style_emoticons/default/beer3.gif) Photos coming soon. Michel Wow...first start is always a nail-biter with new injection--congrats! A couple of things come to mind: 1. What are the A/F R's at idle? It doesn't take much air at all & I'm going to bet it's quite lean. 2. How much advance do you have in at 1000, 1500, 2000 RPM? I'm at 14, 15 & 21 at those speeds on my SDS system. 3. I'm assuming you're on MAP sensing for fueling--what vacuum reading are you seeing at idle? Do you have a "wild" cam in there? This is gonna be fun.... |
Lo-Fi Version | Time is now: 13th May 2024 - 03:10 AM |
