Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
Michelj13 |
Feb 5 2013, 10:33 AM
James,
Step 1: I have checked that all cylinders are firing. However, when I pulled coil connections, there is more of a change when pulling 3 and 1 than 2 and 4. I will need to recheck this. I have a friend that has a compression checker that I need to invite over. I was thinking this may have something to do with injector pairing? Step 2: I tried to do this, see photo, but my idle advance may be too high. All sensors read what I think they should including TPS. Step 3: “Tune idle for max vacuum.” and “ Play with the fueling” . Those are new concepts for me. I need to keep this in mind. Thanks for pointing this out. Step 4 and 5: Current AFR and VE tables attached. “IGNORE EVERYTHING you have read in MS documents” Wow, as I have said in my videos, I have often found it very difficult to get exactly the info I needed to get this Megasquirt project up and rolling. Everyone’s configuration is different and the info on the internet spans a long period of time where many things keep changing for many reasons. James, you have given me a lot to chew on here I could not attach is my current MSQ (not sure why as I have see some posted?). I can email it to you. Feel free to modify, comment or suggest anything. I also want to learn how to use the logger. Thank you for your input, (IMG:style_emoticons/default/smile.gif) Michel Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 01:00 PM |
