Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
aircooledtechguy |
Feb 5 2013, 10:55 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) with everything above.
My VE table is about 25-30 LOWER on almost all values. ie, my idle on the ve is around 22 @ 900rpms. I would recommend highlighting all cells and lowering them all by around 20-25 and then run autotune. As you are right now, you will be pig-rich everywhere which will make it run poorly. |
JamesM |
Feb 5 2013, 11:09 PM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
(IMG:style_emoticons/default/agree.gif) with everything above. My VE table is about 25-30 LOWER on almost all values. ie, my idle on the ve is around 22 @ 900rpms. I would recommend highlighting all cells and lowering them all by around 20-25 and then run autotune. As you are right now, you will be pig-rich everywhere which will make it run poorly. VE values are relative to a bunch of other settings and can vary quite a bit from one car to another depending on how they were setup. Unless it is known that every peice of hardware and setting is 100% identical, just copying someones VE table will not give good results. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:11 AM |
