Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
Michelj13 |
Feb 7 2013, 10:28 PM
QUOTE I just looked up the 9530 and jake states on his site that it is not compatable with ANY injection, stock or aftermarket. I also saw another ports where he recomends not using the 9530 on a 2270. Interesting. I spoke to Jake personally on a couple of occasion and he was very helpful. We also exchanged emails. He sold me that cam knowing the displacement, stroke, bore, and compression I wanted to achieve (8.3 on all cylinders). I also purchased pistons and other parts from him. It ran ok with carbs except for sluggish mid range. I was hoping FI would correct for this. Hope it does. In fact, I purchased one of his early customs grinds back in 2005 that had very similar specs to the 9530. I ran this in a 2270 high compression engine. That engine did not idle well, but, over 3k it pulled like crazy to redline and more. Too bad I used poor re-built heads and dropped a seat, but that is another story (IMG:style_emoticons/default/sad.gif) What I have is what I have. We will make the best of it for now. Engine would not start today. Needed to charge battery. I will let you know about MAP reading at idle once I get going again. Alpha-n? Who runs in this mode? |
JamesM |
Feb 8 2013, 12:17 PM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have read posts on other forums with people using the 9530 with FI just fine, so i am not sure why jake says on his store that it is not FI compatable. Honestly it does not concern me to much as I am pretty sure that if an engine runs, it can be made to run with Megasquirt one way or another, given all the options that are available.
Alpha-N is for use in situations where there is low manifold vaccum, usually ITBs or extreme cams. A guy I work with run Alpha-N on his GTI rally car with ITBs. It does not use the MAP value to calculate fuel but rather throttle position and RPM. I am sure only Jake knows the full specs of the 9530, but from what I am reading it does not seem that extreme, so there may be somthing else out of place here. Where are you pulling your MAP signal from? When was the last time you did a valve adjustment? As with everythign Megasquirt related, tons of reading involved. This just touches on it http://www.extraefi.co.uk/MAP_Alpha_N.htm |
Lo-Fi Version | Time is now: 13th May 2024 - 01:41 PM |
