Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
Michelj13 |
Mar 4 2013, 05:24 PM
Sunday, I had some time to do some tuning. I was able to identify without a doubt that the "0" marking on the fan was indeed TDC. I even put a wooden stick down the #1 plug hole and rotated the engine to make sure piston was at its highest at that point.
Knowing this, I got the engine started, but could not get it to idle at 1000 RPM unless timing was set to +5 degrees as observed at the fan. It did idle nicely with this timing. With a bit of throttle input, the engine speed increased nicely to the maximun ignition advance set to 33 degrees, at which point I could see the 28 timing mark on the fan. I don't know how to explain this (IMG:style_emoticons/default/screwy.gif) I am really starting to think, this cam was not the best choice for my engine (IMG:style_emoticons/default/sad.gif) |
JamesM |
Mar 4 2013, 06:14 PM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Sunday, I had some time to do some tuning. I was able to identify without a doubt that the "0" marking on the fan was indeed TDC. I even put a wooden stick down the #1 plug hole and rotated the engine to make sure piston was at its highest at that point. Knowing this, I got the engine started, but could not get it to idle at 1000 RPM unless timing was set to +5 degrees as observed at the fan. It did idle nicely with this timing. With a bit of throttle input, the engine speed increased nicely to the maximun ignition advance set to 33 degrees, at which point I could see the 28 timing mark on the fan. I don't know how to explain this (IMG:style_emoticons/default/screwy.gif) I am really starting to think, this cam was not the best choice for my engine (IMG:style_emoticons/default/sad.gif) I am not sure I follow exactly what you are saying, Is the issue that what you are actually seeing on the fan is not matching what MS is showing? If so there should be an adjustment for that though I would have to look it up as i run a different code version and trigger with my setup. If 5deg advance at idle is what you are actually seeing then you should be ok there. I have mine at 8deg but only because that is as low as I can set it with my particular trigger setup. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:30 PM |
