Megasquirt Project, .....IT RUNS ! |
Michelj13 |
Sep 1 2012, 07:45 PM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart. Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see. I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated. I made a youtube video of my progress up to date. Enjoy! http://www.youtube.com/watch?v=RoJfMZ9YgQc Michel (IMG:style_emoticons/default/smile.gif) |
Michelj13 |
Mar 6 2013, 08:56 AM
I had a bit of a breakthrough last night. I swapped my injector plugs around "just to see" and this resulted in a much smoother running engine. It was dark and I am not sure who is on who, but it ran better, no doubt. Also, it was idling (1000 rpm)at TDC instead on 5 ATDC! VE analyse was working too (IMG:style_emoticons/default/smile.gif)
James,your description of timing in excellent. Thanks. I printed the timing label and cut it out and compared it with the markings on my fan. It all matches. I even calculated the distance between fan blades to 7.3 degrees! My friend has a timing light with wasted spark setting that I need to borrow to confirm my timing. JP, I have been wondering about air leaks also. I will try your suggestion Thanks. OMG, alpha N again (IMG:style_emoticons/default/confused24.gif) I will try that too to see. It is amazing how much fuel I am using tuning this thing! |
JamesM |
Mar 6 2013, 12:50 PM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Stay away from Alpha-N for now, that should be the absolute last resort. From what I have read about your cam, and the fact that you are running from a common plenum I dont think you will need to go there.
You will be suprised how much timing and fuel changes can affect your idle vaccum, I was. |
Lo-Fi Version | Time is now: 12th May 2024 - 03:23 PM |
