has any one done a ecotec swap |
Pass45 |
Sep 11 2012, 07:35 PM
Member Group: Members Posts: 52 Joined: 31-March 12 From: Wildwood il Member No.: 14,323 Region Association: None |
The Motor mounts are going to be fun t he one side wont be bad but I don't have a clue what to do about the other side the stock mount is on the front of the head
Lennies914 |
Sep 11 2012, 07:46 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Look at the motor mount used in the marine application (wiki I think). I looks like a straight bar 914 mount (IMG:style_emoticons/default/biggrin.gif) .
http://www.google.com/imgres?num=10&hl...29,r:1,s:0,i:76 |
Pass45 |
Sep 11 2012, 08:23 PM
That looks like it could work
Lennies914 |
Sep 11 2012, 09:05 PM
I considered this conversion myself. (IMG:style_emoticons/default/beer.gif) |
Pass45 |
Sep 12 2012, 07:37 PM
I'm definitely going to have to lower the transmission
Attached thumbnail(s) |
bfrymire |
Sep 12 2012, 07:54 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Forgive me for slight hijack.
does anyone know what rwd trans will work with this motor? ( I have a rwd car that needs a motor...) thanks. --brett |
Pass45 |
Sep 12 2012, 08:22 PM
I'm not sure who makes it but they make a bell housing for a t5
that bolts to the ecotecs |
Pass45 |
Sep 12 2012, 08:32 PM
Kessler engineering
Pass45 |
Sep 15 2012, 04:44 PM
The top fits (IMG:style_emoticons/default/piratenanner.gif) and I won't have to cut the trunk nowhere as mu h as I did in my parts car
Pass45 |
Sep 15 2012, 04:50 PM
Now I just need to make motor mounts (IMG:style_emoticons/default/welder.gif)
bfrymire |
Sep 15 2012, 04:59 PM
Mike Bellis |
Sep 15 2012, 05:15 PM
(IMG:style_emoticons/default/confused24.gif) Well. it's been a week... Is it running yet? (IMG:style_emoticons/default/poke.gif)
Keep up the good work. I remember when I installed a Mustang 5.0 in my first 914. Car on a lift, Cherry picker holding the engine in and me on my knees welding. (IMG:style_emoticons/default/welder.gif) Now I don't have a lift so I use jackstands and I'm laying on my back. My trusty Area 51 welding jacket on to stop the burning sensation... Damn, I need to get back to my engine/trranny swap... |
Pass45 |
Sep 15 2012, 05:33 PM
Ha I have no plans on making it run at least not in this car its going in this 1
Pass45 |
Aug 13 2013, 12:35 PM
LotusJoe |
Aug 13 2013, 03:44 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm a Zetec guy. But I did find some information on the Ford Duratec engine that replaced the Zetec.
http://duratec.wikispaces.com/ I have actually been considering an engine swap myself except I would use the Zetec because of the lower cost of after market parts for tuning. Here is a couple of pictures of the Zetec after all the Fuel injection stuff has been removed. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lotuseuropa.org-11085-1376430253.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lotuseuropa.org-11085-1376430253.2.jpg) |
Cupomeat |
Aug 13 2013, 04:16 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Forgive me for slight hijack. does anyone know what rwd trans will work with this motor? ( I have a rwd car that needs a motor...) thanks. --brett You can you use the trans from the Saturn Sky/Pontiac solstice, if that works for you. It is made for that motor. It is the same trans as the Chevy Colorado trucks (same years as Sky/solstice) and is cheap and plentiful in the used market. The trans is a coarse unit, but very stout. This is a cool, unusual swap. Good luck! |
Pass45 |
Aug 15 2013, 04:07 PM
How much can I lower the transaxle without running into problems
Rand |
Aug 15 2013, 04:23 PM
I'm late to this thread, but how does anyone not know about ecotech today? If yours is a dog, or if you don't get it, then hello, there's this thing called Google. Those little bitches can scream to 1000hp.
Pass45 |
Aug 16 2013, 12:53 PM
Pass45 |
Aug 16 2013, 01:17 PM
Lo-Fi Version | Time is now: 3rd June 2024 - 03:09 AM |
