SCCA minimum weight, with or without driver? |
Woody |
Sep 13 2012, 12:22 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
SCCA lists my minimum weight as 1863 lbs. Is this with or without the driver? Also is fuel load considered into this? Currently the car weighs in at 1871 with a couple gallons of fuel but without me in it.
ConeDodger |
Sep 13 2012, 01:16 PM
Apex killer! Group: Members Posts: 23,578 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
IIRC it is without driver... I agree though, the GCR is not clear on this. Try asking on the SCCA forum.
BMXerror |
Sep 13 2012, 09:10 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
What class?
Mark D. |
Woody |
Sep 14 2012, 05:29 AM
BMXerror |
Sep 14 2012, 09:13 PM
Without driver. Appendix A of the SCCA solo rules, page 198. Modified classes are the only classes that weigh with the driver.
Mark D. |
Woody |
Sep 14 2012, 09:51 PM
Thanks Mark. (IMG:style_emoticons/default/smile.gif)
BMXerror |
Sep 14 2012, 10:31 PM
You're welcome... You actually got me looking into using a 911SC for STR.
Mark D. |
Woody |
Sep 15 2012, 06:25 AM
ottox914 |
Sep 15 2012, 06:35 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
SCCA lists my minimum weight as 1863 lbs. Is this with or without the driver? Also is fuel load considered into this? Currently the car weighs in at 1871 with a couple gallons of fuel but without me in it. Sounds like you are right where you need to be. Don't forget they will weigh the cars after your last run at Nationals, and not making weight would be a sad thing. Better to be over by 5 pounds than under by 1. |
J P Stein |
Sep 15 2012, 09:30 PM
We used to fill the gas tank in the pits just prior to the last run at the NT events although it was a 5 gallon tank...each day.....you need a manned fire extingusher standing by during a gas up.
Ayup, we were that close to minimum weight. There is variation in scales, BTW. Always weigh up prior to the event on the scales at the venue. |
Lo-Fi Version | Time is now: 7th May 2024 - 02:58 PM |
