Woody
Sep 13 2012, 12:22 PM
SCCA lists my minimum weight as 1863 lbs. Is this with or without the driver? Also is fuel load considered into this? Currently the car weighs in at 1871 with a couple gallons of fuel but without me in it.
ConeDodger
Sep 13 2012, 01:16 PM
IIRC it is without driver... I agree though, the GCR is not clear on this. Try asking on the SCCA forum.
BMXerror
Sep 13 2012, 09:10 PM
What class?
Mark D.
Woody
Sep 14 2012, 05:29 AM
QUOTE(BMXerror @ Sep 13 2012, 10:10 PM)
What class?
Mark D.
SSM
BMXerror
Sep 14 2012, 09:13 PM
Without driver. Appendix A of the SCCA solo rules, page 198. Modified classes are the only classes that weigh with the driver.
Mark D.
Woody
Sep 14 2012, 09:51 PM
Thanks Mark.
BMXerror
Sep 14 2012, 10:31 PM
You're welcome... You actually got me looking into using a 911SC for STR.
Mark D.
Woody
Sep 15 2012, 06:25 AM
QUOTE(BMXerror @ Sep 14 2012, 11:31 PM)
Mark D.
That is a very popular class down here if not the most popular.
ottox914
Sep 15 2012, 06:35 AM
QUOTE(Woody @ Sep 13 2012, 01:22 PM)
Sounds like you are right where you need to be. Don't forget they will weigh the cars after your last run at Nationals, and not making weight would be a sad thing. Better to be over by 5 pounds than under by 1.
J P Stein
Sep 15 2012, 09:30 PM
We used to fill the gas tank in the pits just prior to the last run at the NT events although it was a 5 gallon tank...each day.....you need a manned fire extingusher standing by during a gas up.
Ayup, we were that close to minimum weight. There is variation in scales, BTW.
Always weigh up prior to the event on the scales at the venue.
