POR-15 treated/sealed fuel tank with all new SS hardware $250 |
Rotary'14 |
Sep 14 2012, 07:11 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I have an extra tank (or two) that was boiled out and prepped and sealed with POR-15 fuel tank sealer. I have all new gaskets, sealing rings, and new strainer for the fuel line. I also have SS screws and washers for the filler neck and fuel level sender. This is for a tank, no fuel level sender, or filler neck is included.
I would like $250 + shipping from Los Angeles. -Robert |
wingnut86 |
Sep 14 2012, 07:55 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Which years are they?
The early and late tanks differ in the mounting ear locations for the expansion tanks. ...just saying. |
Rotary'14 |
Sep 14 2012, 08:07 PM
I believe I have both styles early, and late.
Lingcuisine |
Sep 14 2012, 09:42 PM
Newbie Group: Members Posts: 30 Joined: 24-July 11 From: Gulfport, MS Member No.: 13,358 Region Association: South East States |
I would like the tank that will work with 1975 914.
Is PayPal ok for payment? Thanks Jeff |
Rotary'14 |
Sep 14 2012, 10:50 PM
Lingcuisine |
Sep 15 2012, 06:38 AM
Great!
Thanks Jeff |
Rotary'14 |
Sep 17 2012, 04:51 PM
I need some help IDing some tanks,,, I thought I had (1) 75 tank, (2) 74 tanks, and (1) 73 tank
Attached thumbnail(s) |
Rotary'14 |
Sep 17 2012, 04:54 PM
This end is different
Rotary'14 |
Sep 17 2012, 04:56 PM
Inside looks like this on all of them.
wingnut86 |
Sep 17 2012, 05:04 PM
You should only have 2 main styles.
Early & Late - check to PET catalogue. For the part numbers, but the senders will work across the years. The one without the large end tab should be later. Applebees ribs are blurring my response. Your filler will be different as well, charcoal canister is different (although will work) and then your edge protectors and lines are different as well as the caps. I also remember there being something difderent about the internal baffles, but it escapes me currently. Threads are all 17mm on the nipples, with different hole feeds... |
Lo-Fi Version | Time is now: 26th May 2024 - 03:16 PM |
