Compression Test Results |
kbrunk1 |
Sep 15 2012, 05:56 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Got HF testor.
Got 145, 150, 150, 165 lbs Any comments here? I hope this works ....Still on blocks Ken What gives on the 145 lb cylinder? |
mrholland2 |
Sep 15 2012, 06:11 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
quadracerx |
Sep 15 2012, 06:17 PM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
You could try squirting some motor oil down the "weak hole" if the compression comes up...then the rings in that cylinder arent sealing all the way...but honestly those numbers dont seem too out of line...
Sep 15 2012, 07:18 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Double-check the valve adjustment and then drive it.
--DD |
VaccaRabite |
Sep 15 2012, 08:20 PM
En Garde! Group: Admin Posts: 13,455 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Your compression is fine. Go drive your car.
Zach |
dlee6204 |
Sep 15 2012, 08:45 PM
euro911 |
Sep 15 2012, 09:57 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Double-check the valve adjustment and then drive it. --DD A 20 lb different between two cylinders is significant, but I (IMG:style_emoticons/default/agree.gif) ... a valve may just be adjusted a little too tight. |
IronHillRestorations |
Sep 16 2012, 10:45 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If the engine hasn't been run regularly those number could change a bit.
Lo-Fi Version | Time is now: 30th May 2024 - 03:22 PM |
