Any comments here? I hope this works ....Still on blocks Ken
What gives on the 145 lb cylinder?
mrholland2
Sep 15 2012, 06:11 PM
QUOTE(kbrunk1 @ Sep 15 2012, 04:56 PM)
Got HF testor. Got 145, 150, 150, 165 lbs
Is that 1,2,3,4? Or is #3 the 145?
quadracerx
Sep 15 2012, 06:17 PM
You could try squirting some motor oil down the "weak hole" if the compression comes up...then the rings in that cylinder arent sealing all the way...but honestly those numbers dont seem too out of line...
Dave_Darling
Sep 15 2012, 07:18 PM
Double-check the valve adjustment and then drive it.
--DD
VaccaRabite
Sep 15 2012, 08:20 PM
Your compression is fine. Go drive your car.
Zach
dlee6204
Sep 15 2012, 08:45 PM
QUOTE(Vacca Rabite @ Sep 15 2012, 10:20 PM)
Zach
euro911
Sep 15 2012, 09:57 PM
QUOTE(Dave_Darling @ Sep 15 2012, 06:18 PM)
--DD
A 20 lb different between two cylinders is significant, but I ... a valve may just be adjusted a little too tight.
IronHillRestorations
Sep 16 2012, 10:45 AM
If the engine hasn't been run regularly those number could change a bit.
