Its ALIVE |
Its ALIVE |
machina |
Oct 27 2004, 03:04 PM
Fired on the first rotation after the ignition and fuel were turned on.
I primed the oil system with an external pump so she had pressure after about 5 seconds of cranking. Then I flipped the fuel on and the ignition on and she just cranked right over. The idle is seems real slow and loppy (sp) because of the big cam. Revs like a banshee with the light flywheel and clutch. Now I'll take her off the jackstands and see if I can get the clutch and tranny sorted before this weekends race. Thanks Jake, keep you posted. Also, got the Excellence today. Haven't read it yet but looks like a long article. |
mharrison |
Oct 27 2004, 03:13 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
AWESOME!!! I'm always glad to hear when another teener is coming back to life!!!!
(IMG:style_emoticons/default/smilie_pokal.gif) |
Joseph Mills |
Oct 27 2004, 06:17 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
QUOTE(synthesisdv @ Oct 27 2004, 03:04 PM) Fired on the first rotation after the ignition and fuel were turned on. Congrats Dave! (IMG:style_emoticons/default/smilie_pokal.gif) Where's the pics? (IMG:style_emoticons/default/unsure.gif) |
machina |
Oct 27 2004, 07:55 PM
QUOTE(joseph222 @ Oct 27 2004, 08:17 PM) Congrats Dave! (IMG:style_emoticons/default/smilie_pokal.gif) Where's the pics? (IMG:style_emoticons/default/unsure.gif) I've posted alot during the install and rebuild, but here are a few. Gonna update my site with some details about the process and fabrication. Every part of this process has been a learning experience for me and I couldn't have done it without all your help (the club). Thanks for that. (IMG:style_emoticons/default/beer.gif) Before this the most I ever did myself was bleed brakes and change wheels. One great part of this is that now I can tackle just about any problem that comes up. At the track it will really help because now I can adjust the clutch or troubleshoot the electrics etc. At school they say "see one, do one, teach one" now I can teach one. Attached thumbnail(s) |
DonTraver |
Oct 27 2004, 08:08 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
SWEET!!!!!! (IMG:style_emoticons/default/smilie_pokal.gif)
ChrisReale |
Oct 27 2004, 08:20 PM
well done. (IMG:style_emoticons/default/beer.gif)
dinomium |
Oct 27 2004, 10:50 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Looks pretty, smells nu, bet it goes like stink!
congrats a nice work... (IMG:style_emoticons/default/smilie_pokal.gif) |
Jake Raby |
Oct 28 2004, 05:59 AM
Great work!!
Its suppose to crank on the first turn- we built it! |
maf914 |
Oct 28 2004, 06:04 AM
Dave,
Way to go! Are you using a stock tachometer, and if so, does it work with the Mallory HiFire ignition box? Any adapters necessary? |
machina |
Oct 28 2004, 06:08 AM
QUOTE(maf914 @ Oct 28 2004, 08:04 AM) Are you using a stock tachometer, and if so, does it work with the Mallory HiFire ignition box? Any adapters necessary? That's a good question, I have no idea. I was so intent on watching the oil pressure gauge that I don't even remember if the tach was working! I only ran it a couple minutes because the back of the car is towards the back of the garage about 2' from the door to the house. Still smells like race exhaust in here. Today I'll try and connect the clutch, take her off the jackstands, and roll her out. I do remember a while back someone saying that their tach worked OK with the Hyfire, I'll let you know. |
machina |
Oct 28 2004, 06:29 AM
mike,
just did a search... http://www.914world.com/bbs2/index.php?act...13362&hl=hyfire seems you have to use the lead from the dizzy (green wire) not the tach wire (yellow) from the Hyfire. Guess I'll be doing a little re-wire. (IMG:style_emoticons/default/wacko.gif) |
Joseph Mills |
Oct 28 2004, 07:43 AM
QUOTE(synthesisdv @ Oct 28 2004, 06:29 AM) http://www.914world.com/bbs2/index.php?act...13362&hl=hyfire seems you have to use the lead from the dizzy (green wire) not the tach wire (yellow) from the Hyfire. Guess I'll be doing a little re-wire. (IMG:style_emoticons/default/wacko.gif) Dave, I just read the old thread you referenced and then re-read my instructions. It clearly states to connect the yellow wire coming out of the box to your tach lead. As I recall, I followed the instructions and this is how I have mine configured and my tach works fine. Unfortunately, my wires are bundled and covered up right now so I can't confirm at this moment. I would be hesitant to start switching wires around. I will check when I return home and let you know what I find. Or maybe someone else will chime in to clarify. |
machina |
Oct 28 2004, 07:46 AM
QUOTE(joseph222 @ Oct 28 2004, 09:43 AM) I just read the old thread you referenced and then re-read my instructions. It clearly states to connect the yellow wire coming out of the box to your tach lead. As I recall, I followed the instructions and this is how I have mine configured and my tach works fine. Unfortunately, my wires are bundled and covered up right now so I can't confirm at this moment. I would be hesitant to start switching wires around. I will check when I return home and let you know what I find. Or maybe someone else will chime in to clarify. Appreciate the followup. I have the yellow wired now as the instructions outlined and I will test it before I start changing things. That said, on the STF I read that these old tachs need the signal from the dizzy, not the CD unit. That may be why you used the green from the dizzy. I'll just crank her over and see if it works with the yellow, let you know later. thanks. |
Joseph Mills |
Oct 28 2004, 08:18 AM
QUOTE(synthesisdv @ Oct 28 2004, 07:46 AM) That said, on the STF I read that these old tachs need the signal from the dizzy, not the CD unit. That may be why you used the green from the dizzy. Just to clarify, I did not use the "green" wire. It was Serge that posted that he used the green wire. Anyway... your installation looks really clean and that Raby 4 is going to SCREAM! (IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 11:50 AM |
