Door Lock, How to disassemble |
eric914 |
Oct 27 2004, 07:18 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
Any trick in removing the plastic slider on the lock. The lock pictured has a broken ear and I would like to remove the plastic slider for another lock.
Mark Henry |
Oct 27 2004, 07:37 PM
Just open the handle and it will pull right off, you might have to sneek it out of the grooves.
What'scha buildin dOOd? |
eric914 |
Oct 27 2004, 09:42 PM
I tryed to encourage it and now have a three piece plastic thing. Any other thoughts. Should I drill out the rivet? I have two more locks I would like to get this piece off of. I have one good lock missing this piece.
Mark Henry |
Oct 28 2004, 07:22 AM
You will have to very gently pry the arms to sneek it in.
Try this: http://www.pelicanparts.com/techarticles/9...door_handle.htm |
JZH |
Oct 28 2004, 07:27 AM
Newbie Group: Members Posts: 9 Joined: 14-October 04 From: London, UK Member No.: 2,954 |
Might be a better idea to buy a new replacement "door handle insert" from automotion, etc. The old ones are probably just waiting to break once re-installed in a 914 (on a dark and stormy night, far from home, naturally)...
Ciao, JZH London, UK www.vsource.org |
boxstr |
Oct 28 2004, 09:39 AM
While on this subject,(outside door handles) has anyone taken one completely apart to have rechromed??
I notice that there are two plastic washers or sleeves that are on the flapper handle. Can all of this be taken apart and put together?? Thanks CCLINGASFORGAS |
URY914 |
Oct 30 2004, 06:26 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You can remove the rivet by filing off the bottom of it than drive it out the top.
Make sure you're filing the bottom of the rivet if not, when you reinstall it in the door the rivet will work loose and slide out. DO NOT drill out the rivet. File it and push it out. You have to be able to reuse it so drilling out will destroy it. I rebuild them so if you have questions pm me. Paul |
boxstr |
Oct 30 2004, 06:56 PM
Paul Thank You very much.
CCLINFILEME |
URY914 |
Oct 30 2004, 07:01 PM
Lo-Fi Version | Time is now: 18th May 2024 - 04:51 PM |
