KitCarlson EMS Install, Progress Thread |
McMark |
Oct 27 2004, 08:02 PM
I'm in the process of installing the Beta KitCarlson EMS. Today it ran. I've been working on modifying the wiring harness to match the stock layout. I had one wire in the wrong place today which made it keep running even when the key was off. Fixed that and now it idles great.
Things I've done so far: - Modify the wiring harness. - Buy plug wires that will work with the new coil. - Made an adapter plate to mount the coil in the stock location. Things I still have to do: - Send the harness to Jeff B. for replication. - Fine tune the engine. - Make a mounting plate for the brain to put it in the stock location. |
McMark |
Oct 27 2004, 08:16 PM
Wiring harness. Colorful for now.
McMark |
Oct 27 2004, 08:18 PM
You can see the coil in the last picture, here's the plate I made that will mount it securely in the stock location.
Mark Henry |
Oct 27 2004, 08:55 PM
Where are you mounting the brain?
If you mount the coil and brain too close together you wil get EMP problems...my SDS install manual stressed that you should keep the coil pack at least 3 feet away from the CPU. |
McMark |
Oct 27 2004, 08:58 PM
Stock stock stock. (IMG:style_emoticons/default/biggrin.gif) The box it's in will be grounded to the chassis. (IMG:style_emoticons/default/confused24.gif) It's a stock, stealth replacement. If it causes drivability problem then I'll look for a solution, but I'm not going to start looking for problems to fix.
Brad Roberts |
Oct 27 2004, 09:13 PM
Where is "Kit" on this "kit" ? Are you the only person with a 914 related kit ? I found a dyno in Mountain view that is identical to Jakes and the guy builds alcohol burning T4 quarter midget race engines... he said we could use the dyno for injection tuning.
B |
McMark |
Oct 27 2004, 09:17 PM
I'm pretty sure I have the only 914 kit. I'm sending the harness to Jeff. (IMG:style_emoticons/default/confused24.gif) Dave's not very talkative, so I'm not really sure.
Let me know when and what I need to do and I'll rip it out and bring the engine down. I'm free anytime. (IMG:style_emoticons/default/wink.gif) |
Britain Smith |
Oct 27 2004, 09:28 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Hmmmm....Dyno. I really need to get everything together for my engine.
-Britain |
JeffBowlsby |
Oct 27 2004, 10:08 PM
914 Wiring Harnesses Group: Members Posts: 8,499 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Looks great Mark...You and Mueller are gonna put me outta bizness... (IMG:style_emoticons/default/biggrin.gif)
Any chance I can see this harness installed in the engien bay before you rip it out? How about the breakfast on Saturday? Speaking of which...I invited the owner of that 25-Large yellow 73 to the breakfast....he said he might join us... |
Brad Roberts |
Oct 27 2004, 10:10 PM
Jeff,
Can you call me tomorrow at HPH ?? Or can I call your cell phone ?? I need to ask you a few questions. B |
JeffBowlsby |
Oct 27 2004, 10:12 PM
Sure I'll call you in the morning...
McMark |
Until I get the TPS adapter, I can't drive it. But I'll make it happen. You'll get to see it.
JeffBowlsby |
Oct 27 2004, 10:20 PM
Cool let me know before you pull it...
Brad Roberts |
Oct 27 2004, 10:21 PM
Thanks Jeff,
Mark, I recall seeing the adapter in the box you gathered everything in. I'll look around tomorrow for it however. B |
McMark |
Oct 27 2004, 10:24 PM
I looked everywhere and my shop is cleaner than yours. (IMG:style_emoticons/default/wink.gif) Dave said he'd send me a new one. I'll look some more, and I'd appreciate any looking you can do.
Brad Roberts |
Oct 27 2004, 10:26 PM
I'm one of 3 people total who probably knows what it looks like.
B |
Mueller |
Oct 27 2004, 10:38 PM
are you talking about the adapter on "inside" of the TPS to adapt it to the d-shaft?
Mark, for even more "stealth" you should be able to rip the guts out of the stock TPS (I used a 2.0 unit) and fit the new TPS inside it.... |
McMark |
Oct 28 2004, 02:16 AM
Damn Mike that's a good idea. (IMG:style_emoticons/default/idea.gif)
Jake Raby |
Oct 28 2004, 06:02 AM
Brad, who is this guy??
I have been trying to get up with some of those teams for months but all the ones I have found were running Auto craft engines these days... I was going to try to convert them to TIV with my heads.. Tell that dude that I have a TIV head that flows 280 CFM on the intake and 230 on the exhaust! |
Hi_Fi_Guy |
Oct 28 2004, 09:57 AM
Tuetonic terror Group: Members Posts: 375 Joined: 12-August 03 From: Sunny Phoenix, AZ Member No.: 1,019 |
I just want to thank all the club members working hard to make the Kit Carlson F.I. system a reality.
I think the improved drivability, stealth look (for stock engines), and ability to pass smog test will benefit the entire 914 community for years to come. I also believe that a relieble "bolt-on" F.I. will bring people to the 914 community that are afraid of the old stock F.I., don't like carbs, or want BIG Type IVs without carbs. Thanks again and keep up the great work! |
Lo-Fi Version | Time is now: 12th May 2024 - 04:57 AM |
